Centripetal acceleration problem (very easy)
The centripetal acceleration of a 2.5 kg object moving at a constant speed of 8.0 m/s in a 5.0 m radius circle is calculated using the formula a_c = v^2 / r. The correct acceleration is 13 m/s², derived from the calculation 8² / 5, which equals 12.8 m/s² when rounded. The mass of the object is irrelevant in this context, as acceleration does not depend on mass.
  • Centripetal acceleration formula (a_c = v² / r)
  • Understanding of constant velocity in circular motion
  • Basic knowledge of units of measurement (m/s²)
  • Familiarity with the concept of radius in circular motion
  • Study the derivation of centripetal acceleration in circular motion
  • Learn about the relationship between force and acceleration in physics
  • Explore examples of circular motion problems in physics
  • Investigate the implications of mass in different physics equations
Students studying physics, educators teaching circular motion concepts, and anyone looking to understand the principles of centripetal acceleration.
coding_delight
A 2.5 kg object moves at a constant speed of 8.0 m/s in a 5.0 m radius circle. What is the object's acceleration?
I'm quite sure the answer to the problem is 32 m/s^2, but apparently the right answer is 13 m/s^2. Unless I'm missing a detail about the "constant velocity" part of the problem, can some one please explain why the answer is 13.
Welcome to PF, Coding... but you're in the wrong forum. This is pretty obviously a homework question, which is not allowed in this section. As such, you must show what you've already done by way of figuring it out.
a_c= \frac{v^2}{r}
The mass is superfluous.
How could you possibly have got "32 m/s^2"? The only way to combine the numbers given to get 32 would be "82 times 2.5 divided by 5". If you do that, your units would be kg m/s2, not m/s2. Since there is no mass unit in acceleration, as bel says, the mass is irrelevant.
duh.. 32 units is the force, 13units is the acceleration
acceleration = v*v/r
= 8*8/5
= 64/5=12.8
= 13 (approx)
  • · Replies 28 ·
  • · Replies 24 ·
