'Centripetal Accelerations' and 'Radius of Curvatures' in Projectile Motion
The discussion revolves around the concepts of centripetal acceleration and radius of curvature in the context of projectile motion. The original poster presents two questions regarding the radius of curvature at specific points in a projectile's trajectory, particularly focusing on the highest point and another point where the velocity makes an angle with the horizontal.
  • Participants explore the relationship between velocity components and the radius of curvature, with some questioning how to determine the vertical component of velocity at a specific angle. There is also discussion about the application of trigonometric identities and the correct interpretation of centripetal force in the context of the problem.
Participants are actively engaging with the problem, offering insights and corrections to each other's reasoning. Some guidance has been provided regarding the use of trigonometric relationships to find velocity components, but there is still uncertainty regarding the correct application of centripetal force and the resulting calculations.
There is mention of potential discrepancies between participants' answers and the book's answer, indicating a need for careful consideration of the assumptions made in the calculations. The discussion highlights the challenge of applying theoretical concepts to specific problem setups.
modulus
The first question:
‘A particle is projected with a speed u at an angle ѳ with the horizontal. Consider a small part of it’s path near the highest position and take it approximately to be a circular arc. What is the radius of this circle? This radius is called the radius of curvature of the curve at that point.’
The second question:
‘What is the radius of curvature of a parabola traced out by the projectile in the previous problem at a point where the particle velocity makes an angle ѳ/2 with the horizontal?’
For first situation: mg = mv2/r
v (at that point) = u cos ѳ
For the second situation: mg cos(ѳ/2) = mv’2/r
v’ = vx + vy
vx = u cos ѳ
The first problem was easy to solve, because we could consider the velocity of the particle at the highest point, which was only u cos ѳ (as the vertical compnent was equal to zero) as v, and, solve using the formula for centripeal acceleration. My answer was: u2cos2 ѳ/g
But, I’m having trouble with the second problem. How can Ifigure out the velocity of the particle at the position mentioned? I can’t figure out the vertical component at that point. Is there any formula or figuring out the velocity of a projrctile according to the angle it makes with the horizontal? Could you please help me solve this problem?
You've got the initial vx from the set up. Assuming we are neglecting air resistance the initial vx is the vx through the entire problem. So when the velocity makes an angle of ѳ/2 with the horizontal you have two parts of the puzzle. You have the horizontal component and the angle that makes with the hypotenuse of the triangle formed from vx, vy, and v’. From there it's a matter of trig. Might I suggest the use of tangent of the angle with the horizontal to find the vertical component or to go directly to v’ the cos of the angle with respect to the horizontal?
You'll want to be careful with your centripetal force as well. It won't be all of mg. It will be just the part of mg perpendicular to v’.
Right!
I figured out the component of vx in the direction of the projectile's velocity. That would be equal to u cosѳ*cos(ѳ/2). But the answer is given only in terms of cos(ѳ/2).
Any trig identity to apply? (Sorry, my trig's really weak).
Never mind, there is a cos(theta) in the answer given in the book.
So mg cos(ѳ/2) = mv'2/r is not correct?
Anyways, I solved assuming the above statement is correct and using what you told me, but the given answer was different again.
My answer: u2 cos2ѳ cos(ѳ/2)/g
Book's answer: u2cos2ѳ/g cos3(ѳ/2)
Did I do something wrong again?
Please help.
That is correct.
u cosѳ*cos(ѳ/2)
This you messed up a little.
cos(ѳ/2) = u*cos(ѳ)/v' because cos of the angle is adjacent over hypotenuse
So:
v' = u*cos(ѳ)/cos(ѳ/2)
Now plug that into mg cos(ѳ/2) = mv'2/r and solve for r and you should get your answer.
  • · Replies 21 ·
