Centripetal And Centrifugal Forces
The discussion centers on the concepts of centripetal and centrifugal forces within the context of uniform circular motion. Participants clarify that centripetal force is a real force acting towards the center of a circular path, while centrifugal force is not a real force but an apparent force experienced due to inertia when in a non-inertial frame of reference. The mathematical derivation provided illustrates how centrifugal force arises from the transformation of acceleration between rotating frames, emphasizing that it is a fictitious force. The consensus is that understanding these forces is crucial for physics students, particularly in the study of dynamics and motion.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of inertia and acceleration
  • Basic knowledge of circular motion dynamics
  • Ability to interpret mathematical equations in physics
  • Study the derivation of centripetal force in uniform circular motion
  • Explore the concept of inertial and non-inertial reference frames
  • Learn about the implications of fictitious forces in general relativity
  • Examine real-world applications of centripetal force in engineering and physics
Physics students, educators, and anyone interested in understanding the dynamics of circular motion and the distinction between real and apparent forces.
danago
Hi. This isn't a homework problem, but I am asking for the sake of adding to my understanding of the topic.
In class, we have just begun uniform circular motion on the horizontal plane.
Now, i understand that for an object to be accelerating (changing direction in this case), there needs to be a net force acting on it, in the direction of the acceleration. When referring to circular motion, this is the centripetal force, which acts directly towards the center of the circle.
I have heard of a centrifugal force. I've searched it on the internet, and most of the things I've read talk about how it doesn't exist. Its a force that people assume to exist, when actually, it is just the laws of intertia kicking in.
Im a bit confused. What exactly is the centrifugal force?
Thanks in advance,
Dan.
The centrifugal force does not exist. Suppose we are in a car, traveling round an arc of a circle to the left. Then, we will appear to feel a force pulling us to the right of the car. However, this is not a "real" force, but is simply our body wanting to continue traveling forward in a straight line.
This is one of those cases where searching on the internet may be dangerous, since there will undoubtably be incorrect information on websites out there written by someone who knows nothing about Physics!
Thanks for that. Thats what most sources told me, and they also used the exact same example.
One website told me that centripetal/centrifugal were action-reaction force pairs. Guess that's an example of one of those inaccurate websites
Does anyone wish to comment on this?
http://www.badastronomy.com/bablog/2006/08/30/when-i-say-centrifugal-i-mean-centrifugal/
Hmmm so they are really the same thing then? Just depending on the frame of reference?
Let's look at the mathematical situation. Consider two frames of reference S and S', with S' rotating with constant angular velocity ω. Let r denote the displacement vector of the particle in S, and r' the displacement in S'. Now, I'm sure you'll agree that we can use Newton's second law in frame S, to give us \bold{F}=m\frac{d^2\bold{r}}{dt^2} (1)
Now, let's switch to the rotating frame. Using a general result, we have that the differential operators in S and S' are related by \frac{d}{dt}=\left(\frac{d}{dt}\right)'+\bold{\omega}\times(2)
Differentiating the RHS of (1):\frac{d^2\bold{r}}{dt^2}=\frac{d}{dt}\left(\frac{d\bold{r}}{dt}\right)'+\frac{d}{dt}(\bold{\omega}\times \bold{r})=\left(\frac{d^2\bold{r}}{dt^2}\right)'+\bold{\omega}\times\left(\frac{d\bold{r}}{dt}\right)'+\bold{\omega}\times\frac{d\bold{r}}{dt} (note that since ω is constant, the term involving its derivative vanishes).
So, we have Newton's second law in the rotating frame: \bold{F}=m\left[\left(\frac{d^2\bold{r}}{dt^2}\right)'+2\bold{\omega}\times\left(\frac{d\bold{r}}{dt}\right)'+\bold{\omega}\times(\bold{\omega}\times{\bold{r}})\right], where we have obtained the last term by applying (2) on the corresponding term in the above.
Now, the final term on the RHS is commonly called the "centrifugal force," however we note that it is not a force, but merley arises when converting the acceleration of the particle in S to the acceleration in S'.
The author is perfectly correct. Here's what I tell my students:
"To explain these apparent forces, consider Figure 27.8.3.a, which tracks a particle moving at a constant velocity with respect to an observer in a fixed basis. The time-displacement graph is a straight line. If the observer now moves at a constant velocity in the same direction as the particle (Figure 27.8.3.b), the measured velocity of the particle will be reduced but it will still appear to be constant. However, if the observer accelerates in the direction as the particle (Figure 27.8.3.c) then its apparent velocity will change. A change in velocity is an acceleration and to produce an acceleration requires a force. The accelerating observer thus perceives a force on the particle.
Inertia is an example of an apparent force and the non-inertial behaviour of two cars during a head-on collision is the reason why the kinetic energy calculated by a roadside bystander is different from what would be calculated by either of the drivers. Many authors disdain the use of inertial forces, including centrifugal force, regarding them as ‘fictitious’ but even diehards would agree that gravity is a ‘real’ force. However that disappears in the non-inertial situation called free-fall (incorrectly called ‘weightlessness’). This is the whole basis of general relativity."
You'll get the full discussion in Chapter 27, Section 8 at
http://moodle.gla.ac.uk/eng/moodle/course/view.php?id=40 .
...and try telling the occupants of a cornering car that it's not a 'real' force.
  • · Replies 28 ·
