Centripetal Force - How to describe it?
Centripetal force (F_c) is defined as the necessary force for an object to maintain circular motion at a specific radius and velocity, rather than being a distinct force like friction or gravity. It is the net force causing inward acceleration, which can arise from various real forces such as tension, gravity, or friction. The discussion emphasizes that centripetal force does not indicate a new type of force but rather describes the direction of the net force acting on an object in circular motion. Additionally, the path of the object does not have to be circular; it can take various shapes as long as the non-centripetal component of force remains zero.
  • Understanding of Newton's Laws of Motion
  • Familiarity with concepts of force and acceleration
  • Knowledge of circular motion dynamics
  • Basic grasp of gravitational forces in two-body systems
  • Study the mathematical derivation of centripetal force, specifically F_c = mv^2/r
  • Explore the differences between centripetal and centrifugal forces
  • Investigate the dynamics of elliptical orbits in gravitational fields
  • Learn about the role of tension and friction in maintaining circular motion
Physics students, educators, and anyone interested in understanding the principles of circular motion and the forces involved in maintaining it.
superdave
So I had a thought today, and I wanted to figure out if it's correct or not about centripetal force.
I've always heard it described as the inward force something experiences as it goes around a curve. But could it better be described as the force necessary for an object to maintain circular motion at a given radius and velocity? Because F_c always has to be accounted for with other forces (tension, gravity, friction).
So F_c is not a force itself like friction or gravity is. It's just what we call whatever real force/forces is/are causing the inward acceleration that causes circular motion.
This came about because someone was asking if centripetal force is inward, Newton's Third Law should have an outward force as well. I expained that the outward force is on whatever is causing the inward force (on the other end of the string, the object being orbitted, the other frictious surface, etc...). This led to the fact that F_c is always caused by something else, which led to the fact that F_c = mv^2/r is just a way for us to know what force is necessary to maintain the circular motion for a given r and v, but it doesn't actually account for the force.
Correct, "centripetal" doesn't indicate a new type of force like friction, tension, etc. It's simply an adjective that indicates the direction of the force. In general, it's not even a single force that's involved here, but rather the net force on an object that is moving in a circular path. It's easy to construct situations where no single force points towards the center of the circle, but the net force does.
precisely
Alright, thanks. I'm student teaching now in a HS Physics class. I wanted to make sure my thinking was correct before I passed it on to the students.
Note the path of the object doesn't have to be circular. The centripetal force is the component of force perpendicular to the path (velocity) of an object at an instant in time. If the non-centripetal component of force is zero at all times, then the object moves at constant speed, but it's path could be almost any shape: circle, ellipse, spiral, parabola, hyperbola, sin wave, ... . As an example, imagine the possible paths a car could take while moving at constant speed with just steering inputs.
Yes, I can see how that's true. Though at the high school level, we generally only deal with uniform circular motion (constant centripetal force).
superdave said:
This came about because someone was asking if centripetal force is inward, Newton's third law should have an outward force as well.
One exception to this is a two body system where two objects orbit circularly about a common center of mass. In this case, the Newton third law pair of forces is the gravitational force that accelerates the first object towards the second object, and the gravitational force that accelerates the second object towards the first object, and both forces are "inwards".
I wasn't sure if you also considered elliptical orbits, where gravitational force includes a non centripetal component, except at the ends points of the major axis.
superdave said:
[..] the outward force is on whatever is causing the inward force (on the other end of the string, the object being orbitted, the other frictious surface, etc...). This led to the fact that F_c is always caused by something else [..]
Newton called that, I think, the force of inertia which acts in reaction to acceleration, and it is centrifugal (the term "centrifugal force" is often used with a completely different meaning, causing much confusion).
rcgldr said:
One exception to this is a two body system where two objects orbit circularly about a common center of mass. In this case, the Newton third law pair of forces is the gravitational force that accelerates the first object towards the second object, and the gravitational force that accelerates the second object towards the first object, and both forces are "inwards". [..]
Yes indeed; the objects can similarly orbit circularly attached to each other by a rope or spring. For each object there is a 3d law force pair but the details such as the points where the forces act depend on the situation.
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 73 ·
10K
  • · Replies 18 ·
  • · Replies 37 ·
