Centripetal force while a car makes a turn
The discussion revolves around the concept of centripetal force as it applies to a car making a turn, specifically examining the forces acting on fuzzy dice hanging from a string inside the vehicle. Participants explore the relationships between tension, friction, and centripetal acceleration.
  • Participants discuss the necessity of a free body diagram and equations to analyze the forces involved. There are varying opinions on whether all necessary data is provided to solve the problem. Questions arise regarding the relationship between the tangential velocity of the car and the swinging dice.
Some participants have provided insights into the calculations of centripetal acceleration and the radius of the circular path. There is acknowledgment of potential rounding errors in calculations, and participants are actively questioning the assumptions made about the relationship between the car's velocity and the tangential velocity of the dice.
There is an ongoing discussion about the adequacy of the provided data for solving the problem, as well as the implications of significant figures in calculations. Participants are encouraged to consider the physical setup and its impact on the results.
greenrichy
A pair of fuzzy dice is hanging by a string from the rearview window. While making a right turn at 60 mph, the fuzzy dice makes an angle of 23 degrees from the vertical.
(1) Determine the radius of the circular path of the fuzzy dice.
(2) What is the mechanical force acting as the centripetal force on the following entities:
(a) - The fuzzy dice
(b) - The car
(c) - The driver
None
Correct me if I'm wrong, but I think it is not possible to solve (1) with all the data that's given.
As for (2), I have come up with the following solutions:
(a) - The tension in the string acts as the centripetal force on the fuzzy dice
(b) - The frictional force between the road and the car
(c) - None?
It is. Start with a free body diagram. Write some equations. Some things cancel.
(c) - None?
(a) I would say it's the horizontal component of the string tension.
(b) Correct
(c) Are you sure? Does the driver move in a straight line?
Thanks for your reply. From a free body diagram of FD (Fuzzy dice), I know that we can find the centripetal acceleration, right? But how do I find the tangential velocity?
How is the velocity you are given not the tangential velocity?
So the tangential velocity with which the dice swing is the same as the car's velocity?
Depending exactly on where the dice are laterally within the car and how long the string is, the two speeds are unlikely to be exactly the same, but near enough. It is clear you are expected to take them as the same, but well spotted that they need not be.
So I found that the centripetal acceleration is equal to 4.2 m/s^2. Given all the data that I have, the radius of the circular path of the dice turns out to be 171.3 meters. I calculated it using this formula --> a = v^2/r.
Does it look right?
Does it look right?
That’s about right. I get slightly more. Did you plug in the acceleration as exactly 4.2? That would introduce a rounding error... better to do the entire calculation in your calculator with no intermediate rounding.
Anyway, you are quoting too many sig figs given the input data.
Got it, that makes sense. Thank you for your help.
  • · Replies 18 ·
  • · Replies 28 ·
  • · Replies 20 ·
