Centripetal Motion Velocity vs. Position Angle Assignment
The discussion focuses on proving that the angle between two position vectors is equal to the angle between their corresponding instantaneous velocity vectors in uniform circular motion. Participants clarify that this proof must be conducted without calculus, relying on geometric principles. The key insight is that in uniform circular motion, each velocity vector is perpendicular to its respective position vector, which establishes the relationship between the angles. A diagram illustrating the position and velocity vectors is recommended for clarity.
  • Understanding of uniform circular motion
  • Basic knowledge of vector representation
  • Familiarity with geometric principles
  • Ability to interpret diagrams in physics
  • Study the properties of vectors in circular motion
  • Learn about the relationship between position and velocity vectors in physics
  • Explore geometric proofs in physics without calculus
  • Practice drawing diagrams to visualize vector relationships
Physics students, educators, and anyone interested in understanding the geometric relationships in uniform circular motion and vector analysis.
burtonjib
1. Show that the angle between two position vectors is equal to the angle between two instantaneous velocity vectors eg. v1 and v2 when v1 and v2 are conncected tail to tail in a uniform circle. No angles are given, it is just general.
2. Has to be proven without calculus. No information is given other than the fact that the circle is uniform and therefore the speed is constant.
3. I didn't attempt the question because I'm not exactly sure how to go by proving that the angles are equal.
Do I understand you to be describing two particles in circular motion about a common central point? If so, then what is the angle between each particle's position vector and its velocity vector?
Yes that's exactly it. No angle was given though, the question is just asking to prove that the angle between position vectors is equal to that between the velocity vectors.
Try drawing a diagram. Draw arbitrary position vectors from a common point and then draw a velocity vector from the head of each position vector. Keep in mind that circular motion makes each velocity vector normal to its corresponding position vector.
I don't really see how that would show the equality between θ1 and θ2
If two lines intersect at an angle θ, at what angle do their normals intersect?
  • · Replies 31 ·
