espen180
- 831
- 2
No physical measurements have zero uncertainty. Any attempt to measure the delay of the wire will yield some distribution of delay times.
The discussion centers around the claim made by a CERN team regarding the measurement of neutrinos traveling faster than the speed of light. Participants explore the implications of this claim for established theories such as Special Relativity (SR) and Quantum Electrodynamics (QED), as well as the methodologies used to obtain these measurements. The conversation includes both theoretical interpretations and practical concerns regarding measurement accuracy.
Participants do not reach a consensus on the validity of the measurements or their implications for existing theories. Multiple competing views remain regarding the interpretation of the results and the reliability of the experimental methods.
Limitations in the discussion include unresolved questions about the accuracy of distance measurements, potential errors in the experimental setup, and the assumptions made regarding the mass of photons and neutrinos.
This discussion may be of interest to those studying particle physics, theoretical physics, and the implications of experimental results on established scientific theories.
TrickyDicky said:Well, maybe so, still it would look to me a excesively "ad hoc" explanation but then I guess the only way to know for sure is repeating the experiment again in similar temporal circumstances to see if that distribution is eliminated.
In any case if the loose wire had such a behavior I'm not sure it would correspond to a systematic type of error.
Drakkith said:You want to repeat the experiment with a loose wire just to see if that particular fault was the cause of the errors? There's no reason to. They fixed it and the results immediately showed a change. In any case i doubt one could reproduce the exact amount of "looseness" in the wire the previous experiment had, so I don't know if it could even work.
Histspec said:Well, if the time of every single event is displaced by 59ns, then of course also the whole spectrum is changed in the same way.
TrickyDicky said:Wait, do you mean then
neutrinos actually had that broad variation in their speed but just shifted 59ns to have close to light speed average?
Dickfore said:yes, see their table of systematic errors.
TrickyDicky said:How can neutrinos have such different speeds?
ZapperZ said:Why is the original OPERA paper still being debated here? It is clear that the result from that paper no longer holds water.
Zz.
TrickyDicky said:Sorry, I thought this thread was specifically for discussion of that paper, if that is no longer the case I guess I'll just have to try elsewhere.
ZapperZ said:It makes discussion of the original paper to be entirely moot!
TrickyDicky said:Even to get a better understanding of how exactly is the result invalidated according to the CERN press report? You give the term "discussion forum" a different sense from the one I'm used to. I thought one of the goals of such forums was asking questions in order to understand scientific issues thru the clarifications of other more learned forum members.
ZapperZ said:Unless you are in possession of a detailed report on the exact timing errors that was done in the original OPERA result (i.e. you have the post-mortem analysis of those loose connection), what exactly do you have to base on in doing your "discussion"? The original OPERA paper certainly didn't have any. And the recent report on those loose connectors certainly have been lacking in the details on what exactly is the timing errors and how they were measured. So what exactly are you going to base your discussion on? SPECULATION? Guess work?
The same "philosophy" what was imposed upon in the beginning to urge people to read the original OPERA paper BEFORE they jump in into this discussion is also at work here. It means that the discussion must be based on something concrete, rather than something pluck out of thin air without any basis. Until the OPERA group publish clearly the post-mortem of the original result, you and I do not possesses any kind of data or information to make an informed discussion of what actually happened. So how would such a discussion gives you a "better understanding"? A better understanding on how to make guesses?
Zz.
TrickyDicky said:So far I've obtained two different explanations to my query, one that the loose wire error is purely sistematic and fixed (74ns) and the other that it actually it is responsible for the broad variation of [itex]\delta[/itex]t in the first longer Opera experiment from 2008-2011.
Both answers are incompatible; as I said since the cable problem is considered a sistematic error I was thinking in terms of the first explanation, and with the reasonable assumption that neutrinos speed cannot oscillate so much in such a short distance (732km), I'm still missing something in the sense that the offered solution would work perfectly if the 60ns [itex]\delta[/itex]t was not just an average. Of course my concern is only directed to the original experiment, not to the recent brief short pulsed ones. But I think it is important given the uproar it generated to have it all well clarified.
