Find Forces at Hooks on 42N Flexible Chain
  • Thread starter Thread starter Jacob87411
    Chain Forces
The discussion focuses on calculating the forces exerted by hooks on a flexible chain weighing 42.0 N, which hangs at an angle of 41.5° with the horizontal. The forces exerted by each hook are determined using trigonometric functions, yielding horizontal and vertical components of 31.5 N and 27.4 N, respectively. The total force exerted by each hook is confirmed to be 21 N when considering equilibrium conditions. The tension in the chain at its midpoint is also derived from these calculations, emphasizing the importance of understanding the equilibrium of forces acting on the chain.
  • Understanding of basic trigonometry (sine and cosine functions)
  • Knowledge of equilibrium conditions in physics
  • Familiarity with vector components of forces
  • Concept of tension in flexible structures
  • Study the principles of static equilibrium in mechanics
  • Learn about tension forces in cables and chains
  • Explore applications of trigonometry in physics problems
  • Investigate the Pythagorean theorem in force resolution
Physics students, mechanical engineers, and anyone involved in structural analysis or mechanics will benefit from this discussion, particularly those interested in force calculations and equilibrium conditions in flexible systems.
Jacob87411
A flexible chain weighing 42.0 N hangs between two hooks located at the same height (Fig. P12.19). At each hook, the tangent to the chain makes an angle = 41.5° with the horizontal.
(a) Find the magnitude of the force each hook exerts on the chain.
(b) Find the tension in the chain at its midpoint.
So the hook exerts both a X and Y force.
Fx=Cos(41.5)(42)=31.5
Fy=Sin(41.5)(42)27.4
using pythagorean theorem you get total force=42N, or you could use cos^2+sin^2=1 to get the same answer..so 21N on each hook?
Your approach is not quite correct. Realize that the force exerted on the chain is always tangent to the chain (in other words, parallel to the line of the chain); it is equal to the tension force exerted by the chain at the ends. Since the chain is in equilibrium, the sum of the vertical forces must equal zero. (So find the vertical components of the forces on the chain.)
Yes the force from each chain minus the chain should be zero because it is in equilibrium..so do you find the vertical force from the chain then that combined with the forces from the hooks is zero?
There are three forces acting on the chain: force from the left hook, force from the right hook, and the weight. Find the vertical component of each of these forces.
