Chain Rule and Partial Derivatives for Differentiable Functions
  • Thread starter Thread starter manenbu
    Chain Chain rule
manenbu
Prove that if
[tex]z(x,y)=e^y f(ye^{\frac{x^2}{2y^2}})[/tex]
is differentiable, then
[tex](x^2-y^2) \frac{\partial z}{\partial x} + xy\frac{\partial z}{\partial y} = xyz[/tex]
Chain Rule.
A similar question is solved like this:
Have this:
z(x,y) = f(x² - y²)
Prove this:
y(∂z/∂x) + x(∂z/∂y) = 0
I define
z = f(u)
then
u = x² - y²
∂z/∂x = ∂z/∂u ∂u/∂x = ∂z/∂u 2x
∂z/∂y = ∂z/∂u ∂u/∂y = ∂z/∂u -2y
adding it up:
y(∂z/∂x) + x(∂z/∂y) = y*∂z/∂u*2x - x*∂z/∂u*2y = 0
When I try the same for the mentioned problem, I run into problems and just can't get it right. I guess it's something with the multipilication in there - but can't figure it out.
What's the correct way?
So for example, to start off
[tex]\frac{\partial z}{\partial y} = \frac{\partial (e^y)}{\partial y} f(ye^{\frac{x^2}{2y^2}}) + e^y \frac{\partial f(ye^{\frac{x^2}{2y^2}})}{\partial y}[/tex]
Why don't you work through the two partial derivatives and let us know what you get?
ok so we got:
for shortness:
[tex]f(ye^{\frac{x^2}{2y^2}}) = f(u) = f[/tex]
define:
[tex]u = ye^{\frac{x^2}{2y^2}}[/tex]
let's do the derivative:
[tex]\frac{\partial z}{\partial y} = e^yf + e^y\frac{\partial f}{\partial u}\frac{\partial u}{\partial y}[/tex]
noticing that eyf is the same as z:
[tex]\frac{\partial z}{\partial y} = z + e^y\frac{\partial f}{\partial u}\frac{\partial u}{\partial y}[/tex]
and doing the derivative:
[tex]\frac{\partial z}{\partial y} = z + e^y\frac{\partial f}{\partial u}(e^{\frac{x^2}{2y^2}}+y\frac{x^2}{2}\frac{-2}{y^3}e^{\frac{x^2}{2y^2}})[/tex]
let's make it look better:
[tex]\frac{\partial z}{\partial y} = z + e^y\frac{\partial f}{\partial u}(e^{\frac{x^2}{2y^2}}-\frac{x^2}{y^2}e^{\frac{x^2}{2y^2}}) = z + \frac{\partial f}{\partial u}e^{\frac{x^2}{2y^2}+y}(1-\frac{x^2}{y^2})[/tex]
I'll make this substitution for readbility:
[tex] \frac{\partial f}{\partial u}e^{\frac{x^2}{2y^2}+y} = a[/tex]
so I end up with:
[tex]\frac{\partial z}{\partial y} = z + a(1-\frac{x^2}{y^2})[/tex]
doing for the other derivative now:
[tex]\frac{\partial z}{\partial x} = a\frac{x}{y}[/tex]
now the proof:
[tex](x^2-y^2)a\frac{x}{y} + xy(z+a-a\frac{x^2}{y^2} = a\frac{x^3}{y}-axy+xya-a\frac{x^3}{y} + xyz = xyz[/tex]
Problem solved. Thanks a lot!
Was also using this for a bit of tex practice.
Looks so easy now.
