Change in chemical energy of rocket
20 replies · 2K views
isukatphysics69
19800*.35 = 6930J
isukatphysics69 said:
19800*.35 = 6930J
What is the relationship between the energy expended, the useful work done, and the efficiency?
energy expended divided by work is efficiency?
Would that tend to produce a value > 1 or < 1?
it depends tho
it depends tho
Will the work expended be more or less than the useful work done?
Where might the work expended go?
ok so since there is wasted energy then the work expended is more than the useful work done
So what would be a sensible way to define efficiency?
so 35/100 particles of rocketfuel are usefull
so that's 35% so 35% of the total energy is 35% of 19800
haruspex said:
Right, so what should you do with the 19800J you calculated?
so total energy expended was 19800 jules. only 35 percent of that is used efficiently so out of the total 19800 6930 was put to use that's what i thought
No. How did you calculate the 19800 J? Go back and check.
oh yea ok so the change in chemical potential energy was 19800 joules
There are the following quantities of work...
Useful work done
Total work done
19800J
GPE gained
KE gained
Chemical PE lost
Work lost to heat, sound etc.
What are all the relationships between these?
Useful work done
Total work done
19800J
GPE gained
KE gained
Chemical PE lost
They all have to do with energy
No, I mean what equations relate them. Some are equal, some add up to equal others...
haruspex said:
There are the following quantities of work...What are all the relationships between these?
Total work done = GPE gained + Work lost to heat, sound etc. + KE gained
Chemical PE lost = 19800J Since it is the change in PE
Useful work done = KE gained​
Yes.
No. Look at how you calculated 19800J in post #1. I see nothing about chemical PE there.
You left out GPE gained.
haruspex said:
Yes.
ok there is a mistake there both sides should be multiplied by negative 1 so CPE final - CPE initial will be ΔCPE
No.
Please try to address my points in post #19.
