Change in Velocity Homework: Solving the Vector Difference
8 replies · 4K views
Jimbo57
A car's velocity changes from 13.9 m/s east to 12.8 m/s northeast. What is the change in it's velocity?
It's a 4 marker.
Honestly, I don't really know how to start this. I know it's a vector difference and I've drawn the diagram which isn't too tough. The fact that I'm using a negative vector is throwing me off.
Could anyone nudge me in the right direction?
How are you using a negative vector?
Vector subtraction?
v2-v1= v2+(-v1)
So does the 13.9 m/s here, not turn into a negative value?
It's a 4 marker.
It's the length and direction of the vector that goes from the first velocity to the second velocity. The difference vector isn't so much 'negative' as merely heading in a different direction.
If you have studied about vectors and unit vectors then try finding unit vectors along north and north east.
Unit vectors have zero magnitude of 1 and a direction
So, vector(v) = magnitude(v) * direction (v)
Or, vector(v) = magnitude(v) * unit vector (v)
Just subtract the two vectors you get to get the final vector, and then find its magnitude.
PS: you wil always get a positive change as magnitude of a vector is always positive.
You subtract. Subtract vectors. One way to do that is to write each vector in north and east "components"- ie < 13.9, 0> for the first vector and <a, b> for the second vector where [itex]\sqrt{a^2+ b^2}= 12.8}[itex]and, because "northeast" has equal parts "north" and "east", a= b.<br /> <br /> Alternatively, you could do this "trigonometrically". Represent each velocity vector as a line, "13.9 m/s east" of length 13.9 to the right, and "12.8 m/s northeast" of length 12.8 making an angle of 45 degrees with the first line. The "difference" is the third side of that triangle.[/itex][/itex]
[itex][itex] <br /> Ahh so "Northeast" represents an exact angle of 45 degrees? I had a hunch of this, but couldn't find it anywhere. That helps a lot!<br /> <br /> Thanks everyone else for your help too![/itex][/itex]
yes NE means 45 angle with both north and east direction,
Quote by HallsofIvy
[itex][itex] <br /> Something about the question is throwing me off... <br /> <br /> Using vector subtraction I get 62° (61.8°) North of East -(Xtotal =4.85 m/s East & Ytotal =9.05 m/s North)<br /> Using trigonometry I get 62° (61.8°) North of West<br /> <br /> I think the second answer is right (North of West), not sure though. <br /> Can anyone help explain what I'm doing wrong?[/itex][/itex]
