Change in wavelength, photon hits a free electron.
The discussion focuses on the calculation of the change in wavelength of a photon after colliding with a free electron at rest, utilizing the principles of conservation of energy and momentum. The derived formula for the change in wavelength, based on Compton scattering, is Δλ = 2h/(m_e c) when the recoil angle is 180°. The equations used include the conservation of energy and momentum, specifically hf_i + m_e c² = hf_f + √(p_e² c² + m_e² c⁴) and p_i = p_f + p_e. The solution confirms that the problem simplifies when considering the specific case of 180° recoil.
  • Understanding of relativistic energy and momentum equations
  • Familiarity with Compton scattering principles
  • Knowledge of photon properties, including wavelength and momentum
  • Basic algebra and manipulation of equations
  • Study the derivation of the Compton scattering equation in detail
  • Explore applications of conservation laws in particle physics
  • Learn about relativistic effects in high-energy collisions
  • Investigate the implications of photon-electron interactions in quantum mechanics
Students and educators in physics, particularly those focusing on quantum mechanics and particle physics, as well as anyone interested in the applications of conservation laws in high-energy scenarios.
AbigailM
A photon with initial momentum p collides with a free electron having
a mass m that is initially at rest. If the electron and photon recoil in opposite
directions, what will be the change in the photon’ wavelength? (Hint: use
relativistic forms for energy and momentum.)
Conservation of Energy:
hf_{i}+m_{e}c^{2}=hf_{f}+\sqrt{p_{e}^{2}c^{2}+m_{e}^{2}c^{4}}
Conservation of Momentum:
\boldsymbol{p_{i}}=\boldsymbol{p_{f}}+\boldsymbol{p_{e}}
I won't go through the whole derivation as it's quite a bit of latex but:
If you square both equations above and introduce hf into the conservation of momentum equation, you can equate the two equations and rearrange. This will give you the compton scattering equation:
\lambda_{2}-\lambda_{1}=\frac{h}{m_{e}c}(1-cos\theta)
If the recoiling electron and photon are to be in opposite directions this is an angle of 180°.
Plugging this into the compton scattering equation gives:
Δ\lambda=\frac{2h}{m_{e}c}
,which is the change in wavelength.
Does this look ok? As always everyone, thanks for the help!
Looks ok. But it seems to me that the intent of the problem was to set up the conservation equations for the specific case of 180 degree recoil. That makes the messy algebra simpler than the general case.
However, if you can go through the algebra for the general case and then substitute the specific value of theta at the end, then that should certainly count as a solution!
