Change of momentum of a crate within a system
The discussion revolves around calculating the change of momentum for a 200 kg crate that accelerates from 0 m/s to 9.82 m/s over 20 meters in 4.07 seconds. The initial momentum is calculated as 0 kgm/s, while the final momentum is 1964 kgm/s, resulting in a change of momentum of +1964 kgm/s. The participant initially considered using the impulse formula (force multiplied by time) but confirmed that the change in momentum directly aligns with the impulse definition. Ultimately, they validated their calculations through both methods, reinforcing their understanding of the concepts involved. The conversation emphasizes the relationship between impulse and momentum in physics.
junkie_ball
Ok i am working through some course work questions and have been asked to calculate the change of momentum of the 200kg crate. I have the following information after working through the previous questions
Mass of crate = 200Kg
Distance moved (horizontally) = 20m
time = 4.07s
Initial Velocity = 0 m/s
Final velocity = 9.82 m/s
Aceleration = 2.41 m/s/s
I realize i don't need all this information but wanted to include all the information i have gained about the system. I have also attached my initial free body diagram.
Impulse = ft = mΔv
So this is where I'm having difficulties i think i have got confused with all the information i have already gained about the system but my attempt is as below would appreciate any pointers in the right direction.
Ft = mΔv
F = mΔv/t
F = (200Kg x 9.82m/s)/4.07s
F = 482.56N
What's the initial momentum? What's the final momentum? What's the difference (change)?
Momentum = Mass x Velocity
Initial Momentum = 200 x 0 = 0
Final Momentum = 200 x 9.82 = 1964
So to summarise the initial momentum would be 0 kgm/s and the final momentum is 1964 kgm/s as such the change of moment would be 1964 kgm/s? so the change in momentum would be + 1964 kgm/s?
I thought i needed to use the impulse = force applied x time equation? is this not the change of momentum. Thanks for you help.
You could use the f*t version if you wanted to. You've provided the acceleration and time, and the force can be obtained from f=ma. But it amounts to the same thing, and really, by definition the impulse is the change in momentum so why not go directly there?
gneill said:
You cold use the f*t version if you wanted to. You've provided the acceleration and time, and the force can be obtained from f=ma. But it amounts to the same thing, and really, by definition the impulse is the change in momentum so why not go directly there?
Thanks for the reply. I see your point (why make life difficult! :D) i have just tried the force * time to work out the impulse and that confirms my answer for me. Thanks for the help
  • · Replies 19 ·
