Characteristic Function Integrand Evaluation
CivilSigma
[/B]
I am trying to determien the characteristic function of the function:
$$ f(x)= ae^{-ax}$$
$$\therefore E(e^{itx}) =\int_0^\infty e^{itx}ae^{-ax} dx = a \cdot \frac{e}{it-a} |_0 ^ \infty $$
But I am not sure how to evaluate the integral.
Wolfram alpha suggests this, but I am not sure how to get there.
https://www.wolframalpha.com/input/?i=integral+from+0+to+infitiy+of+e^(itx)*ae^(-ax)dx
[/B]
If you just plug in the limits you get (∞ - ...) which is indeterminate.
CivilSigma said:
[/B]
$$ f(x)= ae^{-ax}$$
[/B]
You have already evaluated the integral; it is not at all indeterminate. If ##F(t) = \int f(t) \, dt## is the indefinite integral, then ##\int_0^\infty f(t) \, dt = \lim_{t \to \infty} F(t) - F(0).## Remember: you were supposed to have ##a > 0,## but you did not actually say that when you wrote the question.​
$$ f(x)= ae^{-ax}$$
The integral is not hard to evaluate if you write it as ##a\int_0^\infty e^{(it -a)x}~dx = \frac a{it - a}e^{(it - a)x}|_0^\infty##. I should add that that last expression should really be ##\lim_{b \to \infty} \frac a{it - a}e^{(it - a)x}|_0^b##. Before going any further, there need to be some assumptions on the value of the expression ##it - a##. You also, can't just "plug in" ##\infty## -- you need to work with a limit as shown above to evaluate the antiderivative.
Makes sense. I assumed that it - a < 0 otherwise the integrand diverges to infintiy.
