Charge 18650 with BCAP0050 2.7V 50F is possible?
  • Thread starter Thread starter fer344
    Charge
Charging a 18650 Lithium Ion battery using a BCAP0050 2.7V capacitor is not feasible due to significant voltage differences and energy limitations. The capacitor, when fully charged, reaches only 2.7V, while a standard 18650 cell requires approximately 3.3V for charging. Utilizing a resistor for voltage dropping in this scenario is inefficient and potentially damaging. Instead, a DC-DC switching voltage regulator is necessary to safely manage the voltage conversion for charging.
  • Understanding of Lithium Ion battery specifications and charging requirements
  • Knowledge of DC-DC switching voltage regulators
  • Familiarity with capacitor energy storage calculations
  • Basic electronics principles related to voltage and current flow
  • Research the operation and application of DC-DC switching voltage regulators
  • Learn about safe charging practices for Lithium Ion batteries
  • Study capacitor energy storage and discharge characteristics
  • Explore mentorship opportunities in battery technology and electronics
Electronics enthusiasts, battery testers, and anyone interested in safe practices for charging Lithium Ion batteries.
fer344
Can I put a resistor and control discharge of BCAP0050 2.7V 50F in order to charge 18650 battery?
Welcome to the PF.
It helps others a lot if you define your terms better so we don't have to go searching for them to decode your post. It looks like you want to use a 2.7V capacitor to charge a single Lithium Ion battery cell. Is that right?
First, you did not say what voltage your capacitor will be charged to. If it is rated at 2.7V, you need to stay below that voltage by some margin, or you can damage the capacitor.
Second, you would not use a voltage dropping resistor in a battery charging circuit. That is just too wasteful of the energy. You would use a DC-DC switching voltage regulator to transform the source voltage to the battery charging voltage.
Finally, as we know from many recent battery fires, charging a Lithium Ion battery is not something to be done by amateurs.
What is the application?
The charged capacitor will be full at 2.7V, while the empty battery will be at 3.3V (in case it is a standard Li-Ion cell). So whatever you do, the current will flow backward, from the battery to the capacitor if connected with a resistor.It'll overload the cap in no time.
The energy stored in the capacitor is around 180Joule, the energy stored in one 18650 cell is ~ 30kJoule (I hope I did the math right). Less than 1%. Even if you can push all the juice in the capacitor into the battery (you can't, and even partial discharge will require complicated electronics due the voltage difference) it won't do much.
Welcome to the PF.
Thanks for response! :)
My interest is on testing batteries, want to control charge-discharge but have not enough knowledge.
Well, especially with Lithium Ion batteries, it would be best if you could find a local person to Mentor you in your learning about battery technology. It can be a bit dangerous to try to figure this out on your own, especially if you don't yet have an EE degree. :smile:
