Charge on a particle to balance its weight
4 replies · 9K views
Fluxthroughme
1. What must the charge of a 1.45g particle be for it to remain stationary when placed in a downward-directed electric field of magnitude 650N/C?
[tex]E = \frac{F}{q}[/tex]
So the field is pointing downwards. E fields point in the direction a positive charge would take, so the charge must be negative to stay balanced. Gravity is also pointing downwards.
So I take the above formula, and I get F = Eq = ma
[tex]q = \frac{(1.45*10^{-3})*g}{650} = 1.488*10^{-16} C[/tex]
(Using g = [itex]6.67*10^{-11}[/itex]) However the answer given is [itex]-21.9\mu C[/itex]
Not sure what I'm doing wrong/missing here?
hey man welcome to physicsforums :)
Why are you using g=6.67*10^-11 ?
Edit: or, what units are these?
I'm trying to balance the weight of the particle (mg) with the force from the electric field (Eq).
Thanks for the welcome ;D
Edit: the original particle is 1.45grams, so I use the [itex]10^{-3}[/itex] to convert that to kg. E is in N/C, and g, well I don't know :P Whatever the units of the gravitational constant are
Ohhhhh. I see what I've done! Doing dimensional analysis shows I have the wrong units; thanks for that.
I have to use 9.81 instead of the gravitational constant -_-
Thanks :P
Edit: Yeah, thanks ap123 :P I certainly won't make THAT mistake again ;D
g is the acceleration due to gravity, not the gravitational constant, ie g should be 9.80m/s2
Edit: OK - you've got it :)
