Find Coulomb Charge on Two Repelling 1g Masses | Homework Help
  • Thread starter Thread starter physics(L)10
    Charge Mass
The discussion focuses on calculating the charge on two equally charged 1g masses that repel each other, balancing the gravitational force with Coulomb's force. The relevant equations include Newton's law of gravitation (F=Gm1m2/r²) and Coulomb's law (F=Kq1q2/r²). The participants clarify that 'r' represents the distance between the two charges, and the gravitational force can be simplified to F=mg near the Earth's surface. The challenge lies in solving for charge (q) and distance (r) simultaneously, as there are two unknowns with only one equation provided.
  • Understanding of Coulomb's law (F=Kq1q2/r²)
  • Familiarity with Newton's law of gravitation (F=Gm1m2/r²)
  • Basic knowledge of gravitational force (F=mg)
  • Concept of charge quantization (1 Coulomb = 6.25 x 1018 electron charges)
  • Explore the concept of electric charge and its quantization.
  • Study the relationship between gravitational and electrostatic forces in detail.
  • Learn about solving systems of equations with multiple unknowns.
  • Investigate practical applications of Coulomb's law in physics experiments.
Students studying physics, particularly those focusing on electrostatics and gravitation, as well as educators seeking to clarify concepts related to forces and charge interactions.
physics(L)10
Two equally charged 1g masses repel each other. The lower mass is held fixed.
a)What is the charge on each mass for the Coulomb force to balance the gravitational force of the Earth on the upper mass?
b)How many elecetrons does this rep?
F=Gm1m2/r2, where G=6.67x10-11
F=Kq1q2/r2, where K=9x109
I know to find the charge on each mass we first use the gravitational equation and then use Coulombs law equation to find out the charge on each mass:
F=Gm1m2/r2
=(6.67x10-11)(1)(1)/r2
I'm pretty sure this is right but I'm just confused what r is. Could it be 5.0x10-11 which is the distance between an electron and proton?
b)This is simple. When you find out the coulomb charge, you use 1Coulomb=6.25x1018 electron charge.
Look at your relevant equations. What distance does "r" represent in the first equation? What about the second equation?
I believe r in the first equation is between the centr of the Earth and the object, so would it just be as if the object is on the surface of the earth. And the 2nd equation is the distance between the two objects.
Correct. Note that, near the surface of the Earth, the gravitational force can be written as F = mg. In other words, GME/RE2 is replaced with g. Does this help?
Alright so let me attempt this:
F=mg=(1)(9.8)=9.8. This can then be used:
F=Kq1q2/r2
9.8=(9x109)(q1q2)/r2, but then I'm still confused with what r is. Is it what I said?
Actually, 1 g = 0.001 kg and that's the mass you should use. We have now sorted out the r's. Here r represents the separation between the two charges. Now since q1=q2, the equation that you wrote becomes
kq2/r2 = mg
This is one equation with two unknowns, q and r. To solve this for q (and r), we need either one more equation or one more value for the one of the unknowns. This is because different charges will give rise to different separations in the Earth's gravitational field. I don't see where one can get one more equation. Does the problem provide one more value?
Nope, I double-checked the problem and I wrote it exactly the same. Is it possible we can used substitution? Ex, solve for q and then plug it back into solve for r.
Solve what for q and then plug back in what? You only have one equation and two unknowns. If you do that to the one equation you have, you will end up with 0 = 0. Think of it this way. There is an infinity of pairs of q and r such that
mg = kq2/r.
Well I don't know what to do then lol.
You could ask the person who asked you to solve this problem for a clarification.
Alrighty, thanks a lot :)
