Charge on object between two charged plates Problem
1 reply · 5K views · last reply
Galileo_Galilei
http://aycu16.webshots.com/image/13135/2004772066267823450_rs.jpg
The mass of the ball is 40 milligrams, the applied potential difference is 480 V and the plate separation is 6 cm. If the string hangs at an angle of 20deg to the vertical, determine the charge on the pith ball.
E = V / d
E = F / q
I figured first i should use E = v/d so i did
E = 480/0.06 = 8000
Then i found F using trig and vectors
Cos20 = (40*10^-6) / F
Thus F = 4.26*10^-4 N
Then i plugged in my F and E into the equation q = F / E
q = 4.26*10^-4 N / 8000 = 5.3*10^-9 C
Which is 5.3 nC
But the correct answer is supposed to be 18nC
Forever grateful for assistance.
You must consider all forces, including the tension in the string. That will affect where the ball hangs. Draw a free body diagram. Resolve the tension into its components, and sum up the forces in each direction.
