Charge on three metallic plates
  • Thread starter Thread starter zorro
    Charge Plates
37 replies · 5K views · last reply
zorro
3 metallic plates are placed at a separation d1 and d2 as shown in figure. A charge Q is given to the middle plate which is free to move, then
A)it will slide towards left if d2>d1
B)it will slide towards right if d2>d1
Diagram of three parallel metal plates between two grounded wires, with the middle plate free to move; gap d1 between the left plate and middle plate, gap d2 between middle plate and right plate.
I found out the charge distributions on the the first and last plate as -Qd2/d1+d2 and -Qd1/d1+d2 resp.
Now to calculate the force on the middle plate due to one plate (say first), shall I take the charge on the middle plate as Q or Qd2/d1+d2 ?
  • Diagram of three parallel metal plates connected to ground: a middle plate free to move, with gap d1 to the left plate and gap d2 to the right plate, both gaps labelled.
take it as Q ... net charges on plates will give force b/w the plates
Even I thought so...but that does not give the correct answer XD
does the other way around give correct answer?
Since the middle plate and the outer plates have opposite charges, the middle plate experiences a tug-of-war.
Yes it does, but why don't we take the net charge on the middle plate to find out the force of attraction acting on it due to other plates?
Are the charges on one side isolated from one plate?
The charges sit on both surfaces of the inner plate. They feel the electric field built up in the empty space at their side. The charges are attached to particles of the plate, cannot leave it plate, so the plate feels the force due to the electric field at the left-hand side and a force of opposite sign from the right-hand electric field. The plate will slide in the direction of the resultant force.
ehild
Refer this:
Hand-drawn diagram of a rectangular plate with rows of small plus signs on both its left and right faces, and a point labelled P to the left of the plate.
(I lost my patience while drawing + signs :biggrin:)
The electric field at point P is due to the left and right side of the charged plate.
  • Hand-drawn diagram of a rectangular charged plate with rows of plus signs on its left and right sides, and a point P marked to the left of the plate.
It is a metal plate, Q charge on both sides. When the area of the plate A is big the electric field is homogeneous near the plate and far from the edge at both sides. Apply Gauss' law. 2A*E=2Q/ε: The electric field strength is Q/(Aε) that is, the surface charge density/ε.
In terms of electric field lines, the electric field strength is the number of field lines crossing perpendicularly an unit area. For an isolated point charge Q, the number of field lines crossing the surface of a sphere of radius R is
Q/(4πεR2) * (4πR2) = Q/ε,
that is Q/ε field lines emerge from a positive point charge of magnitude Q. In case of a surface charge on a metal plate, all the field lines point outwards so E=Q/(Aε).
In your case tha surface charge density is different at the sides of the metal plate so the electric fields are different to. You can imagine the three plates as two different capacitors connected to the same potential.
ehild
I agree with that.
But in the problem, the middle plate has different charges on either side.
Consider a cylinderical Gaussian surface passing through the plate.
(E1+E2)A=(Enet)A=(Q1+Q2)/ε
i.e. The total electric field at any point in between the two regions on either side of the middle plate equal Q1 + Q2 = Q/ε
Proceeding this way I don't get the correct answer.
Meanwhile I edited my post, read it. You assumed that the electric field is the same at both sides. Try to choose a Gaussian surface with one base inside the metal.
ehild
No I did not assume the fields to be same. That is why I used E1 and E2.
"Try to choose a Gaussian surface with one base inside the metal. "
That will give electric field only due to one of the sides of the plate (E1 or E2)
What are E1 and E2? Is E1 the electric field at one side and E2 the electric field at the other side? Then what is E net?
(E1+E2)A=(Q1+Q2)/ε is correct, but it does not mean that E1=E2.
Gauss'law states that the electric flux through a closed surface equals to the enclosed charge divided by ε. It does not matter how much charges are outside. You know that the electric field is zero in the metal. Choosing the closed surface with one base inside the metal and the other base just outside, the total flux is A*E1 =ε Q1. The same is valid for the other side: A*E2=ε Q2. So E1=Q1/ε and E2=Q2/ε.
Forget Gauss' theorem for a minute.
Refer the figure in #9.
Consider the charges to be different on both sides.
Now at the point P, is there any electric field due to the charges on the other side of the plate?
The electric field lines do not penetrate inside the metal. There is no electric field at one side originating from the surface charges on the other side.
ehild
I think that 'penetrate' is not the right word here. Its just that the field lines don't exist inside a metal/conductor.
Consider a situation where a charge q is placed at the centre of an uncharged spherical metallic hollow shell. There are no field lines inside the shell but they are present outside the shell!
Consider this situation too-
Diagram of a circle with two horizontal arrowed lines entering from the left and two leaving on the right, with arrowheads showing direction of travel.
The field lines come out from the other side though they don't exist inside.
What I am trying to say is that the plate in our case should not shield the electric field due to charges on one side.
  • Diagram of a circle with two horizontal arrowed lines entering from the left and two leaving to the right, showing a process or interaction region.
Have you learned about capacitors?
Assuming that they can thought of as parallel plate capacitors with the same plate area, A, C1=Aε0/d1 and C2=Aε0/d2.
Both capacitors are grounded on one side. The potential difference across each capacitor is the same.
[tex]V=\frac{Q_1}{C_1}\ \text{ and }\ V=\frac{Q_2}{C_2}\,,\text{ where }Q_1+Q_2=Q[/tex]
That should allow you to compare the charge on each side of the common metal plate, and thus compare the electric field on each side.
Why would I name the thread 'Capacitors' without knowing anything about them? :rolleyes:
I already found out the charge distribution. My problem is something else (refer previous posts).
Yes that comes out using formulae.
But I am thinking about the problem another way. Why is the electric field between the first two plates only due to the charge on the middle plate on one side and not due to the other side? The electric field due to the charges on the other side cannot be shielded by a metallic plate (Why? - refer post #17)
Look at the pic
Diagram of three vertical parallel metal plates; the left plate is labelled -Q1, the middle plate is labelled Q1 and Q2, and the right plate is labelled -Q2. Red arrows between the plates show electric field directions.
i have shown only for +-Q1 ... the field outside the region b/w them has no field as their fields gets canceled as shown in fig.
hence there will be no force on Q2 due to -Q1
  • Diagram of three vertical parallel metal plates; the leftmost is labelled -Q1, the middle one Q1 and Q2 on its two faces, and the rightmost -Q2. Red arrows show electric field lines between the plates pointing left and right.
In the absence of external plates, if you put a charge Q on a single thin plate, the charge spreads uniformly on both sides of the plate. What is the electric field near a side of the plate?
Next consider a neutral plate and you bring near it (to some distance d) a second plate carrying a charge Q. What is the disposition of charges on the neutral plate?
Bring another charged plate near the other side of the neutral plate, again with charge Q and this time distance d2. What's the distribution of charges on the neutral plate?
Now use superposition.
@cupid.callin
I don't understand your figure totally but one comment-
Q1 and Q2 are different...the field does not get cancelled.
the fields i have shown are only due to -Q1 n Q1
if Q2 was supposed to cancel the field then that means that there is field at position of Q2 ... then why there would be a question ... the fields of "" ---Q1 and -Q1 --- "" at position of Q2 are canceled ... that's why q2 experience no force
its Q/Aε (if A=area of the plates)
The distance between the plates does not affect the distribution of charges (as long as it is not infinite). The neutral plate remains neutral with 0 charge on both sides.
I have no idea what you are talking about. (btw your figure is deceptive- there is no field line inside a plate!)
Look in your textbook at how the author arrives at the field of a parallel plate capacitor.
I read it 5 times.
That does not help. In the derivation, there is no charge on the outer sides of the two plates. That makes things easier.
Abdul Quadeer said:
I read it 5 times.
The charge on the outside is (should be) outside of the Gaussian surface.
