Charge redistribution on capacitors
  • Thread starter Thread starter Jahnavi
    Capacitors Charge
7 replies · 3K views · last reply
Jahnavi
I will name the top left capacitor A , bottom left capacitor B and right capacitor C .
Before the switch is closed , charges on A and B will be 20 μC each and that on C will be 40 μC .
After the switch is closed ,both A and B will be shorted . Charge on C will be 60μC .
A and B will get discharged i.e there will be no charge on A and B .
On doing further calculations I am getting all four options correct .
The correct answer i.e incorrect statement is 3) .
But if charge on C changes from 40μC to 60μC , doesn't this mean 20 μC has flown through the battery and battery has done 0.6 mJ work or 0.6 mJ energy is supplied by the battery ?
Find the total energy in the circuit before and after the switch is closed. The difference between the two energies would be the energy supplied by the battery.
I don't think this is correct :smile:
You are forgetting energy dissipated as heat .
Also, the second option is confusing (or should I say 'tricky') because there is no resistance shown in the circuit. I'm afraid that makes this statement incorrect.
Can you correct this statement?
Hint: The '1/2' in the equation for the energy stored in the capacitor.
It doesn't make a difference whether a resistance is shown in the circuit or not :smile: .
Heat is dissipated in the wires .
And the wires are shown to be ideal (although you can assume them to have some resistance).
Anyways , I am finding all four options correct .
Which option do you find incorrect ?
Answer given is 3)
Yes, I misread option C as 30mJ. I agree that all the options are correct.
(I still find dc capacitive circuits very tricky!).
