What Causes Bubble Oscillation According to Gauss's Law?
The discussion centers on the oscillation of bubbles as described by Gauss's Law, specifically the equations governing electric field and pressure. The electric field is defined as ##E=\dfrac{\sigma}{2\epsilon_0}##, leading to the expression for pressure ##P_e=\dfrac{\sigma^2}{2\epsilon_0}##. The equilibrium pressure before charging is given by ##P_i=P_0+\dfrac{4S}{R}##. The analysis involves applying Newton's 2nd Law to derive the oscillation dynamics, resulting in the equation ##\dfrac{\sigma^2}{2\epsilon_0}+\dfrac{4S\delta R}{R^2}=\dfrac{m}{\pi R^2}\ddot{R}##, which suggests simple harmonic motion (SHM) characteristics.
  • Understanding of Gauss's Law and its applications in electrostatics
  • Familiarity with concepts of pressure in fluid dynamics
  • Knowledge of Newton's 2nd Law and its application to oscillatory motion
  • Basic proficiency in calculus, particularly binomial approximation
  • Study the implications of Gauss's Law on electric fields in different geometries
  • Explore the relationship between pressure changes and volume in adiabatic processes
  • Investigate the characteristics of simple harmonic motion (SHM) in physical systems
  • Examine the effects of surface tension on bubble dynamics and stability
Physicists, engineers, and students studying fluid dynamics and electrostatics, particularly those interested in the dynamics of charged bubbles and oscillatory motion.
kenth
A bubble with radius ##R##, mass ##m## and surface tension ##S## has initial pressure inside ##P_i## and outside pressure ##P_0## then charged with surface charge density ##\sigma##, Find the period of the oscillation
Gauss's Law, Laplace equation, Newton's Law of Motion
From Gauss's Law
give ##E=\dfrac{\sigma}{2\epsilon_0}##
##\therefore P_e=\dfrac{\sigma^2}{2\epsilon_0}##
Consider at equilibrium (before bubble being charged)
Using Newton's 2nd Law
##\Sigma F=m\ddot{R}##
Let ##R+\delta R## be the new radius
Give (after binomial approximation) ##\dfrac{\sigma^2}{2\epsilon_0}+\dfrac{4S\delta R}{R^2}=\dfrac{m}{\pi R^2}\ddot{R}##
I think this should be SHM but the equation doesn't look like it, also do I need to consider the fact that ##P_i## decreases due to change in volume?
You need to think of it as an oscillation around the new (i.e. charged) equilibrium. The only reason to bother with the old equilibrium would be to find the amplitude.
And yes, I would suppose the pressure changes adiabatically.
  • · Replies 29 ·
10K
