Charged Particles in Magnetic Fields
An ionized deuteron with a positive charge passes through a velocity selector with electric and magnetic fields of 8 kV/m and 40 mT, respectively. The forces acting on the particle are described by F = qE for the electric field and F = qvB for the magnetic field. By equating these forces, the speed of the ion can be calculated using the formula v = E/B, resulting in a speed of 320 m/s. There is some confusion in the discussion regarding the multiplication of E and B, with suggestions to clarify the calculations. Ultimately, the correct approach to find the speed involves using the relationship v = E/B directly.
predentalgirl1
1. An ionized deuteron (a particle with a + e charge) passes through a velocity selector whose perpendicular magnetic and electric fields have magnitudes of 40 mT and 8.0 kV/m, respectively. Find the speed of the ion
2. When a charge particle moves in a velocity selector, both electric field and magnetic field are there.
Any charged particle in an electric field will feel a force proportional to the charge and field strength such that F = qE , where F is force, q is charge, and E is electric field. Similarly, any particle moving in a magnetic field will feel a force proportional to the velocity and charge of the particle. The force felt by any particle is then equal to F = qv X B , where F is force, q is the charge on the particle, v is the velocity of the particle, B is the strength of the magnetic field, and X is the cross product. In the case of a velocity selector, the magnetic field is always at 90 degrees to the velocity and the force is simplified to F = qvB in the direction described be the cross product.
F = qE and F = qvB
So, qE = qvB
V = E/B
Setting the two forces to equal magnitude in opposite directions it can be shown that V = E/B . Which means that any combination of electric (E) and magnetic (B) fields will allowed charged particles with only velocity (v) through.
3. E = 8 KV/m = 8 x 103 V/m
B = 40 mT = 40 x 10-3 T
V = 8 x 103 x 40 x 10-3
V = 320 m/sec
(Ans)
F = qE and F = qvB
So, qE = qvB
V = E/B
V = 320 m/sec
(Ans)
Why have you multiplied E and B?
(I really don't feel that you should copy and paste almost the entire page from Wikipedia, along with the grammatical and spelling mistakes. Write it yourself.)
If I should not multiply E and B, what
should I do instead to get the correct answer?
F = qE and F = qvB
So, qE = qvB
V = E/B
This is from your post. What do you think you should do to get v?
Given that B =40 x 10 ^-6
E = 8000 V/m
have Bev = eE
v = E/B
v= 8000/ 40 x 10^-6
v= 2 x 10^8m/s
Is the value of B you have used here is correct?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 31 ·
  • · Replies 25 ·
