Charging an super/ultracapacitor from AAA batteries
  • Context: Undergrad
  • Thread starter Thread starter ajd-brown
    Batteries Charging
The discussion revolves around the feasibility of charging a supercapacitor from AAA batteries, specifically focusing on the practical implications for powering a small DC motor in a device designed to lift a payload. Participants explore various aspects of charging times, energy requirements, and alternative designs.
  • One participant questions the feasibility of charging a 25F supercapacitor from AAA lithium batteries, noting the low continuous current provided by batteries.
  • Another participant suggests that charging is possible but will take time, estimating seconds to a minute with a single battery.
  • A participant discusses the design of a device that needs to lift a 100-gram payload and emphasizes the need for higher power output from capacitors compared to batteries.
  • Concerns are raised about the limitations of the motor and mechanical components affecting speed, with a suggestion that more energy may be needed for quicker acceleration.
  • One participant provides calculations for energy storage in capacitors and discusses the importance of using resistors to limit charging current.
  • There is a proposal to consider a coilgun design as an alternative to using a motor, questioning the necessity of a conductive pipe for this approach.
  • Another participant clarifies that a non-conductive pipe would be preferable for the coilgun, discussing the effects of induced currents in conductive materials.
  • A participant contemplates the possibility of increasing voltage to power a more powerful motor, raising questions about the implications for charging times and capacitor selection.
  • There is mention of using a step-up converter to increase voltage, but skepticism is expressed regarding the effectiveness of higher voltage motors compared to lower voltage options.
Participants express a range of views on the feasibility of charging supercapacitors from AAA batteries, with no consensus reached on the optimal design or approach. Multiple competing ideas are presented, including the use of motors versus coilguns, and the implications of voltage and current on performance remain unresolved.
Participants discuss various assumptions regarding charging times, energy requirements, and the characteristics of different types of motors and capacitors. Limitations related to the mechanical design and the specific configurations of the electrical components are noted but not resolved.
ajd-brown
It is possible, but it will take some time (probably of the order of seconds to a minute with a single battery, depending on your setup) to fully charge it.
that is a perfectly acceptable time scale.
I am designing a device that will carry a payload of around 100grams vertically up a pipe for around 2 metres. the motor will power a wheel.
The reason for the involvement of capacitors, is that i am limited to the 'energy' supplied by two AAA batteries.
Obviously capacitors are literally more powerful as they can discharge the same energy faster. the device needs to climb as quickly as possible, so a higher power is better.
how could i best choose a capacitor to run a small DC motor?
I would expect that the motor or the mechanical part afterwards limit the speed. The mass just gains 2J of potential energy (+some friction), something even those AAA batteries could deliver in ~1-2 seconds, I think. If you aim for something significantly quicker than 1 second, you need more energy to accelerate your mass.
Charging a big capacitor is possible, of course - connect it to the battery via some resistor (not too small, but its maximal size depends on the repetition rate of your lifting process).
Lithium batteries are quite powerful. You can easily draw 1A from a AAA.
http://data.energizer.com/PDFs/l92.pdf
If 2 AAA are connected in series you need 2 resistors, each rated for 1.5 Ohm and 2W connected in series to limit the charging current to 1A.
Theoretically 1F would be more than enough. 1F * (2.5V)^2 / 2 = 3.125J
But you have friction and also you want it to move as fast as possible. Therefore you need more. Maybe 3F. But remember that those capacitors are only rated for 2.5V so don't connect 2 AAA batteries directly to it. You need something to limit the voltage. For example the LM350 voltage regulator.
http://www.onsemi.com/pub_link/Collateral/LM350-D.PDF
Only costs between 1 and 2$.
You could also try to do it without a capacitor. The maximum discharge current for AAA lithium batteries is 2A and you have two of them. 2A * 1.5V * 2 = 6W. That should be enough to lift 100g by 2 metres in half a second.
Do you need to use a motor? What about a coilgun? Place copper coils around the pipe and then you shoot the weight up the pipe by discharging a capacitor though the coil.
before i get excited about a coil gun, does the pipe have to be ferrous for that to work?
its a copper pipe
Actually for the coil gun idea to work, the pipe should not be conductive. A plastic pipe would be best.
Although it may also be possible with a copper pipe but with lower speed and several coils wound at different places around the pipe. If there is a magnet attached to the weight you just have to turn on the coil that is closest to the weight and the magnet will be pulled into the coil. But since a current is induced in the copper pipe during the first few milliseconds after a coil gets turned on, the whole thing is slowed down.
i think i will have to stick to the motor driving a wheel as the load isn't dense, it is a large container and will be difficult to incorporate into acoil gun design.
I have been thinking...
more powerful motors operate at higher voltages with higher current (P=VI)
two AAA in series = 3v and ~2A = 6W as you said...
If a 1F cap. holds 3J then it will charge in ~1.5 seconds? (Q=CV Q=IT) charging at 2A.
is there a way to increase the voltage from 3v to say 6 or 12v, supply it to a 6 or 12v capacitor which will take longer to charge because of the reduced current...
this capacitor could then power a more powerful motor which would propel the device up the tube faster...I hope this makes sense.
Anthony
edit:
the load is on the outside of the pipe not inside
If the load is outside the pipe that makes it easier. You could use 3 coils positioned around the base of the pipe and 3 magnets each placed in one of the coils. If you discharge a capacitor through the coils, the magnets will shoot out.
If you want to increase the voltage you can use a step up converter, e.g. this one
http://cds.linear.com/docs/en/datasheet/1073fa.pdf
But I don't think that it will make much of a difference. 12V motors are not automatically more powerful than 3V motors.
A 1F cap at 2.5V holds a charge of 1F*2.5V = 2.5As. At 2A that would charge in 1.25s.
If you get 2A from an AAA cell, the voltage might go down a bit. In addition, I would add some resistor to avoid a short circuit, which leads to a slower charging process. This gives some seconds for the charging process.
It is possible, but I would try to avoid it.
15K
  • Poll Poll
9K
