Check My Logs & Exponential Homework Answers
  • Thread starter Thread starter zebra1707
    Exponential
8 replies · 2K views
zebra1707
Greetings - can someone please check my work, many thanks
If x = 12.4 Find the value of ... correct to two sig fgures
8^(4x/3) / log(base 10) (5x-3/x^0)
= 8^(16 8/15) / log(base 10) (5(12.4)-3 / 1)
= 4.8 x 10^14 (via calc 4.818429574)
Many thanks
This expression, (5x-3/x^0), is ambiguous. Is it (5x - 3)/1 or 5x - (3/1)? If it's the former, you're missing some needed parentheses.
Neither of these expressions is right. Starting with 8^(4x/3), how did you get 8^(16 8/15)? I'm assuming the part in parentheses is 16 + 8/15. If you substitute 12.4 for x, and multiply by 4/3, what do you get?
How did you get 4.8 x 10^14? That would be 480,000,000,000,000, nowhere close to 4.818...
zebra1707 said:
Many thanks
Hi Mark
For this question - I need to substitute 12.4 into all x values.
(5x-3/x to the power 0) so if you substitute 12.4 into the x in this part of the equation (12.4^0), yes, you will get (5(12.4)/1).
Is a substitution question.
I don't yet understand how to add the Maths chararcters in the Forum.
Cheers
zebra1707 said:
Hi Mark
That much is obvious.
No you don't. Where did the 3 go?
I still don't know what you mean when you wrote (5x-3/x^0), so please read what I wrote in my previous post more carefully and answer the questions that I asked.
Cheers
Really sorry,
8^(4x/3) (divided by sign) log(base 10 subscript) (5x-3/x^0) - this is exactly how the question is written.
x to the 0 power is 1 so log(base10)(5x-3/1) = log 59
8 to the power of 4x/3 if you substitute 12.4 into x you get 8 to the power of 16 8/15
So. 8 to the power of 16 8/15 or (16.533333.) (divided by ) log(base10)(5x-3/1) = log 59.
Hope that helps - otherwise not sure how I can explain this further.
If I do this again I get 1.6 x 10^14
Cheers
Yes, it reduces to
[tex]\frac{8^{16.53333..}}{59}[/tex]
but I do NOT get "1.6 x 10^14" for that.
Thanks HOI, I am getting two different answers and getting confused.
Ill have another look at this. Cheers
This is a relatively straightforward problem in using a calculator. You shouldn't be getting two answers.
Thanks Mark, for all your help.
Cheers
