Checking if an integral is less than infinite
  • Thread starter Thread starter atrus_ovis
    Infinite Integral
15 replies · 4K views
atrus_ovis
show if [tex]\int[/tex][tex]\stackrel{+\infty}{-\infty}[/tex]|e-3tsin(t)u(t)|dt < [tex]\infty[/tex]
where u(t) is the unit step function,
u(t)=1 for t>=0
u(t) = 0 otherwise
This is my solution, is it correct / sufficient?
-The integral's bounds can be set from 0 to [tex]\infty[/tex], since u(t), and thus the whole quantity to be integrated, is 0 for t<0.
-e-3t approaches zero, as t approaches [tex]\infty[/tex]
-|sin(t)| is periodic,with upper & lower bounds 1 and 0 respectively.
Thus the whole expression ->0 as t->[tex]\infty[/tex], and the integral is less than [tex]\infty[/tex]
f(x)=1/x goes to 0 as x->infinity. But the integral of that doesn't converge. You need to show more than just that the function goes to 0.
No, this is not a correct proof.
The reduction to [tex]\int_0^\infty e^{-3t}\sin t\,dt[/tex] is correct. However, in order to prove that [tex]\int_0^\infty f(t)\,dt < \infty[/tex], it is not sufficient to show that [tex]f(t) \to 0[/tex] as [tex]t \to \infty[/tex]. (For instance, let [tex]f(t) = 1[/tex] for [tex]0 \leq t \leq 1[/tex], [tex]f(t) = 1/t[/tex] for [tex]t > 1[/tex].)
Mm, yeah you're right..Any ideas,general or specific?
The limit of the expression when t->oo is zero btw.
Use a comparison test to show the integral exists. Find a function such that |e^(-3t)*sin(t)|<f(t) where you can show the integral of f(t) exists.
But since the original function approaches 0 asymptotically (doesn't it?), won't i have the exact same problem with the comparison function?
Pick f(t) so you can integrate it. Being able to integrate it shows it exists. Then if |g(t)|<=f(t) that shows the integral of g(t) exists.
:S
But if i can integrate it, it won't approach asymptotically to zero -> it won't be greater than the original function.
Note that i have to find 'if' it is less than infinity, not to prove it.
atrus_ovis said:
:S
I'm not quite sure what you are getting at here. Is the integral of e^(-3t) from 0 to infinity less than infinity?
I do not know.
e^(-3t) approaches zero, the integral though, i can't tell..
atrus_ovis said:
I do not know.
Do the integration! It's an easy antiderivative. Integrate e^(-3t) from 0 to M and then take the limit as M->infinity. What do you get?
Yes, i digged that up via google just now.
Let me work through it.
(it's Integral( e^(-3t)sin(t) dt) btw )
Actually it's not e^(-3t)sin(t). And that's a little bit hard to do. It's |e^(-3t)*sin(t)|. And that one is REALLY hard to do. I'm just asking you to just do the simple one, e^(-3t). Then argue that if that one exists, then the other one exists by a comparison test.
Awh, damn then.I started doing the e^(-3t)sin(t) through uv substitution.
Well:
Integral from 0 to[tex]\infty[/tex] of e^(-3t), can be rewritten as the integral from 0 to k, where k->[tex]\infty[/tex] of e^(-3t)
I(e^(-3t)) is of course -(e^(-3t) )/3) | from o to k, and plugging in we get
1/3 * (-e(-3k)+e0), which out of the blue, equals 1/3, since e-[tex]\infty[/tex] equals 0 i suppose!
i totally did not see this coming
if the above was right, the problem here is how do we fit in this result to the starting integral
Well:
|e^(-3t)*sin(t)|<=|e^(-3t)|, right? If the integral of e^(-3t) equal to 1/3, can't you say that the integral of |e^(-3t)*sin(t)| is less than or equal to 1/3?
Yes you can!
Thank you so much Dick.
I did learn something today.
