Checking the convergence of this numerical series using the ratio test
10 replies · 2K views
DottZakapa
using ratio test verify if converges
convergence tests
## \sum_{n=0}^\infty \frac {(2n)!}{(n!)^2} ##
##\lim_{n \rightarrow +\infty} {\frac {a_{n+1}} {a_n}}##
that becomes
##\lim_{n \rightarrow +\infty} {\frac { \frac {(2(n+1))!}{((n+1)!)^2}} { \frac {(2n)!}{(n!)^2}}}##
##\lim_{n \rightarrow +\infty} \frac {(2(n+1))!(n!)^2}{((n+1)!)^2(2n)!}##
##\lim_{n \rightarrow +\infty} \frac {(2n+2))!(n!)(n!)}{(n+1)!(n+1)!(2n)!}##
then i don't know what else i can do
Gaussian97 said:
First of all, what does the ratio test say?
that becomes
##\lim_{n \rightarrow +\infty} \frac {(2n+2))!(n!)(n!)}{(n+1)n!(n+1)n!(2n)!}##
Actually the ratio test uses the absolute values, in this case, all terms are positive so doesn't matter but is important to know exactly do the theorems say.
Ok, now using the properties of factorials, do you see any way to simplify this expression?
that is the point, I've already applied all the factorial properties that are in my knowledge. if there are others could you please tell me them? I would really appreciate it :) .
i have always problems with factorials.
thanks
Gaussian97 said:
Well, actually you only need the most fundamental property:
$$n! = n \cdot (n-1)!$$
like this?
##\lim_{n \rightarrow +\infty} \frac {(2n+2)!}{(n+1)(n+1)2n(n-1)!}##
Well, a little bit better. Be careful because ##(2n)!\neq 2n\cdot(n-1)!##, and you can still use this property to further simplify you answer (you can actually get rid of all the factorial terms using this property)
##2n(2n-2)! ?##
DottZakapa said:
##2n(2n-2)! ?##
No, use better the property in the form $$x! = x\cdot(x-1)!,$$ if you substitute ##x=2n## what do you obtain?
Very good! you've been super good, did not consider it.
thanks a lot.
Now it simplified as it should
