How Many Moles of BaCO3 Dissolve in Water Given Kc?
  • Thread starter Thread starter Not a Wrench
    Chem Equilibrium
The forum discussion centers on calculating the number of moles of barium carbonate (BaCO3) that dissolve in water, given a dissociation constant (Kc) of 5.7E-6. The user initially miscalculated the moles by incorrectly dividing by the volume of water instead of multiplying, leading to confusion over the correct approach to solving the equilibrium expression. The correct method involves recognizing that Kc represents concentrations in mol/L, and the user ultimately realizes the need to adjust their calculations to find the correct number of moles.
  • Understanding of chemical equilibrium and Kc values
  • Knowledge of molarity and its units (mol/L)
  • Familiarity with the concept of ICE (Initial, Change, Equilibrium) tables
  • Basic algebra skills for solving equations
  • Study the principles of chemical equilibrium and how to apply Kc in calculations
  • Learn about ICE tables and their role in determining equilibrium concentrations
  • Review unit conversion techniques, especially in the context of molarity
  • Practice solving equilibrium problems involving weak electrolytes and their dissociation
Chemistry students, educators, and anyone looking to deepen their understanding of chemical equilibrium and solubility calculations.
Not a Wrench
Excess BaCO3 is placed in a container containing 5L of pure water. Given the following info:
BaCO3 (s) ↔ Ba2+ + CO3 2- and Kc = 5.7E-6
how many moles of BaCO3 dissolve?
Kc=(Ba2+ )(CO3 2- ) = 5.7E-6
solved for x to get .002387 moles/5L which is incorrect. Dividing by 5L gives me .000477 moles. The correct answer is .012 and I am unsure what I have done wrong. It seemed simple enough. Could someone tell me what to do?
0.002387 is not number of moles.
I forgot to add my last step but I know. It's the moles per liter. If I divide by 5 it gives me .000477 moles which is also not correct.
Not a Wrench said:
.000477 moles
No, it is not moles. Check your units.
Randomly juggling numbers is NEVER a good approach to solving problems.
Then what is x supposed to be? I was under the impression that the number by which it BaCO3 decreases is equal to the x that each of the products increases by.
So you are solving for x not knowing what it is? That's randomly juggling numbers, I told you it doesn't work.
You have calculated something in your first post. What it was? Can you post your whole solution?
Yeah, all I did was calculate 5.7E-6 = x2 and solved for x which got me to .002387. Isn't its units M/5L because the container contains 5L of water?
No, that's not how units work. Units don't contain numbers (or, if anything, we assume all numbers to be equal to 1). Besides, typically by M we denote molar concentration (which has its own units, mol/L ← an important hint here!), not number of moles.
Not a Wrench said:
5.7E-6 = x2
What is x intended to mean in this equation?
The Kc equation contains (Ba2+ )(CO32- ) and they both gain x per the ice chart so therefore Kc = x2
And what you mean by (Ba2+) (or (CO32-))?
Those are the products in the equilibrium. But I figured it out, anyways. I was dividing by 5L of water when I should have been multiplying by 5L because I needed to eliminate that 5L in the denominator and get moles by itself!
These are CONCENTRATIONS. And concentration has units of mol/L. Per ONE liter, not per 5 liters.
When you divided by 5 L you got the result in mol/L2 units - these don't make sense, but you have never checked so you were not able to spot the mistake.
I know, thank you for the hint.
  • · Replies 19 ·
10K
