Chemical Equilibrium: Calculating K with Ideal Gas Law
The discussion focuses on calculating the equilibrium constant (Kp) for the reaction S2(g) + 2H2(g) ←→ 2SH2(g) using the Ideal Gas Law. Given the initial masses of H2 and SH2, and the equilibrium partial pressure of S2 at 0.00188 atm, participants calculated Kp using the formula Kp = pSH2^2 / (pH2^2 * pS2). The final consensus value for Kp is 2.33, following corrections to initial calculations and proper stoichiometric considerations.
  • Understanding of chemical equilibrium concepts
  • Proficiency in using the Ideal Gas Law (PV=nRT)
  • Knowledge of ICE tables for equilibrium calculations
  • Familiarity with stoichiometry in chemical reactions
  • Review the Ideal Gas Law applications in chemical equilibrium
  • Study the differences between Kc and Kp in gas-phase reactions
  • Practice constructing and interpreting ICE tables for various reactions
  • Explore advanced stoichiometric calculations in equilibrium problems
Chemistry students, educators, and professionals involved in chemical equilibrium analysis and gas law applications.
Anna_Kwong
It is a chem equilibrium question, involving the ICE table.
The following reaction:
S2(g) + 2H2 (g) ←→ 2SH2(g)
takes place at high temperatures. If the initial amount of H2 and SH2 is 1.75 g and 1.95 g, respectively, and at equilibrium the amount of S2(g) is found to be 0.00188 atm, what is the value of the equilibrium constant? Please give your answer to three significant figures. Given: T = 1670 K and Reaction Volume = 0.500 L. (Hint: you will need to use the ideal gas law).
pv=nRT, ICE table
What I did was find the the mols of H2 and SH2 since we are given n=m/M. So I have those 2 for "I" initial.
Then I found the equilibrium mols of S2, by plugging into the formula pv=nRt, solving for n=pv/Rt and I get 2.00E-5.
Essentially, I know K = [products]/[reactants]. But I only know the "I" of H2 and SH2, and I only know the "E" of S2.
Your help is greatly appreciated!
K = P(product)/ P(reactant) when everything is in gas state.
how do I figure out the "C" in change? or is that even necessary..
remember when dealing with gases, use partial pressure. when dealing with solutions, use concentration.
ok so, kp= pSH2^2/ pH2^2 x pS2 , i know the value of pS2, which is 0.00188atm, how do I find the other 2 values needed to solve for the kp value? Thanks
My kp value is 0.580, can anyone confirm this please and thanks
Use stoichiometry of the reaction.
Kc vs Kp - it depends on what the question asks. When dealing with gases it is more likely that the answer expected is Kp, but it is also perfectly possible to calculate Kc and it will be a valid answer as well. Whether it will be accepted by your teacher... that's another story.
Seems to me like your Kp value is much too low. Show details of your work.
H2 :1.75g / 2.02g/mol = 0.866mol , use pv=nRT , p = nRT/v = (0.866mol)(0.082)(1670)/(0.5) = 237atm
SH2: 1.95g/34.06g/mol = 0.0572mol, use pv=nRT, p = nRT/v = (0.0572mol)(0.082)(1670)/(0.5)=15.7 atm
S2: 0.00188atm
kp= pSH2^2/pS2 x pH2^2 = (15.7)^2/((237)^2 x (0.00188)) = 2.33, eekk guess my calculations for the first run was incorrect, however, is the work done correctly?
Results looks much better now, although you have not accounted for the fact that your final mixture doesn't contain 1.75 g H2 nor 1.95 g of H2S - the first was produced together with S2, the latter was decomposed. You should use reaction stoichiometry for that.
Not that it will change much, but you should check it to be sure.
