Chemical LaTeX Typesetting - Physicsforums Tutorial
  • Topic: LaTeX
  • Thread starter Monique
    Chemical Latex
60 replies · 196K views · last reply
I think that should do it, it's \varepsilon, unless anyone else has a better method
Hmm--what about an [tex]\xi ^\circ[/tex] ?
I think that most people will undestand that as the standard reduction potential, nevertheless I think that there's a better way to represent it though.
How could I go about using LaTeX on a word/pdf?
[tex]Starch~\xrightarrow{amylase}~C_{12}H_{22}O_{11}[/tex]
The best fancy 'E' I can come up with is
[tex]\mathcal{E}[/tex]
Also, let me try a few more things
[tex]\text{C}_6\text{H}_{12}\text{O}_6\, +\, 6\text{ O}_2\, \xrightarrow{\text{heat}}\, 6\text{ H}_2\text{O}\, + \,6\text{ CO}_2[/tex]
Isn't it better without italicizing the letters?
It is, but then - not everone is fluent in LaTeX enough :)
[tex]10\textrm{K}_{4}\textrm{Fe(CN)}_{6}+122\textrm{KMnO}_{4}+299\textrm{H}_{2}\textrm{SO}_{4}\rightarrow162\textrm{KHSO}_{4}+5\textrm{Fe}_{2}\textrm{(SO}_{4}\textrm{)}_{3}+122\textrm{MnSO}_{4}+60\textrm{HNO}_{3}+60\textrm{CO}_{2}+188\textrm{H}_{2}\textrm{O}[/tex]
That was exported form one of my programs :)
[tex]^{14}N~+~^{1}n~\xrightarrow~~^{1}H~+~^{14}C[/tex]
bomba923 said:
Yes! What is the symbol for it? (the fancy capital E thing)!??
Is it on LaTex??
[tex]\in[/tex]
Is this the one you mean?
Does anyone know how to do a left-right harpoon with labels above and below, I guess like
k1
/________
_________
...k2.../
You know what I mean. I have a reaction going in two directions with a different rate constant in each.
You mean like this? [tex]\rightleftharpoons[/tex]
edit: i just saw you want labels above and below.. sorry, don't know how to do that!
Well, i found something that may help you: ftp://ctan.tug.org/tex-archive/info/symbols/comprehensive/symbols-a4.pdf[/URL] page 41.. although it doesn't work on here since I imagine you need some package.
k1
/________
_________
...k2.../
Try this;
[tex]\mathop{\leftrightharpoons}^{k_1}_{k_2}[/tex]
Code:
blah
[tex]dE = dQ-dW[/tex]
[tex]C=\frac{dQ}{MdT}[/tex]
[tex]dQ[/tex]
[tex]dE[/tex]
[tex]dW[/tex]
[tex]M[/tex]
[tex]dT[/tex]
sorry for spam =(
I have not used these symbols for ages, not to mention in LaTeX. How should I properly format statement "for each a and b belonging to set P if a<b then ab belongs to set P2"?
My idea was that it shoud be something like
[tex]\forall a, b \in P a < b \Rightarrow ab \in P_2[/tex]
but it looks like something run over by a truck.
First post, and it's about LaTeX! I've been working with LaTeX for some time now, and recently started getting serious about typesetting spectroscopic notation. I actually started this post asking a question, but while developing the post, I came across an acceptable answer. As such, the tone of this post will change from question to tip.
I have been trying to typeset any general chemical equation or spectroscopic configuration notation without italics. I have known of the \text{} command, and recently found the \textrm{} command, but both of these complain when there are superscripts, subscripts, or Greek characters within the {} delimiters.
As is shown in this thread, you can easily get away with carefully placing the delimiters and \text{} commands. For example, I want to write the following configuration information:
[tex] \text{4f}^{14}\text{6s6p}~^3\text{P}_1[/tex]
As another example, as was previously posted,
My problem: Although this works, it is quite messy to read for arbitrarily complex expressions. Further, I have to manually ensure this content is in math mode, which can be a pain when applying it to an arbitrary location.
My solution: Use the \mathrm{} command! Here's the same examples, cleaned up a bit using this new command:
[tex] \mathrm{4f^{14} 6s 6p ~ ^3P_1}[/tex]
[tex] \mathrm{10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O}[/tex]
Even better, define a new command which enforces math mode, as well as this Roman font. something like
\newcommand{\chem}[1]{\ensuremath{\mathrm{#1}}}
and then you can just simply type \chem{H_2 SO_4} wherever you want, both inside or outside of math mode. With proper use of whitespace, the LaTeX markup looks more elegant and easy to read/diagnose in my opinion.
Hope this helps! It definitely helps me!
Well, take a look at the actual TeX code for the two examples. To compare, here's the original:
Code:
      10\textrm{K}_{4}\textrm{Fe(CN)}_{6}+122\textrm{KMn  O}_{4}+299\textrm{H}_{2}\textrm{SO}_{4}\rightarrow  162\textrm{KHSO}_{4}+5\textrm{Fe}_{2}\textrm{(SO}_  {4}\textrm{)}_{3}+122\textrm{MnSO}_{4}+60\textrm{H  NO}_{3}+60\textrm{CO}_{2}+188\textrm{H}_{2}\textrm  {O}
and here's the one I propose
Code:
%this should go in your preamble somewhere
%and then later, in your document...
\chem{10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O}
Another advantage is that, should you ever decide that you like italic letters in your formulas, or if you want them bolded or whatever, you can just go edit the \chem definition, and then all instances of that command in your document will take advantage of the global edit.
OK, I'll bite. Placing "\newcommand{\chem}[1]{\ensuremath{\mathrm{#1}}}" within the tex delimiters...
[tex]\newcommand{\chem}[1]{\ensuremath{\mathrm{#1}}}[/tex]
and entering the string you recommended "\chem{10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O}"
yields,
[tex]\chem{10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O}[/tex]
versus just entering the string between tex delimiters...
[tex]10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O[/tex]
Aside from the spacing between the '+' signs, I see no advantage.
For the scope of this forum, try this:
Code:
(tex)%NOTE: replace ( with [ to use!
(/tex)
which should work out to look like
[tex] \newcommand{\chem}[1]{\ensuremath{\mathrm{#1}}}<br /> \chem{10 K_4 Fe (CN)_6 + 122 K MnO_4 + 299 H_2 SO_4 \rightarrow 162 K H SO_4 + 5 Fe_2 (SO_4)_3 + 122 Mn SO_4 + 60 H NO_3 + 60 CO_2 + 188 H_2 O} [/tex]
When you put things in the [tex][/ tex] delimiters here, it looks like it's an isolated environment, and thus any commands you define must be used within that same [tex][/ tex] delimiter. My point here, although it may be a minor one in retrospect, is that I introduce an italic-free typesetting environment for stuff like chemical formulas or spectroscopic notation, which can work independent of an equation block.<br /> <br /> I had assumed this forum was discussing the general application of LaTeX for typesetting chemistry-related stuff. My earlier suggestion of placing the \newcommand{} within the preamble is referring to a LaTeX document, in my case, prepared by MikTeX 2.7.[/tex][/tex]
lemme try
[tex]6CO_2 + 6H_2O \xrightarrow{\mathit{Light Energy}} C_6 H_{12} O_6 + CO_2, \Delta G^{\circ} = +2870~\mathrm{kJ/mol}[/tex]
awsome
Hello,
I was wondering if someone could help me with some latex typeset. I can't find how to do the L- and D- used in chemistry to distinguish the chirality of a compound.
Thanks for your help!
Thanks so much for this thread! I just have one question.
How do I get the equilibrium arrows to stay centered when listed on a page?
[tex]NO_2 + CO~ \xrightarrow{k_1}~ NO + NO_3[/tex][tex]NO_3 + CO~ \xrightarrow{k_2}~ NO_2 + CO_2 +XXXX +YYYYYY +ZZZZZZ[/tex]
Can you see how if this was centered on a page the arrows wouldn't be aligned?
Hi icosane,
Some time ago, I participated in a thread that talked about multi-line equations in LaTeX. You can find it at https://www.physicsforums.com/showthread.php?t=325387.
For your example, try something like:
[tex] \begin{align}\begin{split}<br /> NO_2 + CO~ &\xrightarrow{k_1}~ NO + NO_3\\<br /> NO_3 + CO~ &\xrightarrow{k_2}~ NO_2 + CO_2 +XXXX +YYYYYY +ZZZZZZ<br /> \end{split}\end{align}[/tex]
To show you that the alignment is behaving:
[tex] \begin{align}\begin{split}<br /> NO_2 + CO~ &\xrightarrow{k_1}~ NO + NO_3\\<br /> NO_3 + CO + XXXX + YYYYY + ZZZZZZ~ &\xrightarrow{k_2}~ NO_2 + CO_2 +XXXX +YYYYYY +ZZZZZZ<br /> \end{split}\end{align}[/tex]
I am shocked to see there appears to be no means of illustrating ringed structures since I see none in this thread. I guess I'm just really shocked of this. How can you discuss chemistry with ringed compounds and not have a means of displaying them nicely?
Let's face it - it is not chemical forums, it is PHYSICS forums.
