Choosing the correct radius in a Gauss' law problem
3 replies · 4K views · last reply
bluesteels
A square insulating sheet 80.0 cm on a side is held horizontally. The sheet has 4.50 nC of charge spread uniformly over its area. (a) Estimate the electric field at a point 0.100 mm above the center of the sheet. (b) Estimate the electric field at a point 100 m above the center of the sheet.
E= Q/2eA
Q= (4.5*10^-9)
confused on part A/B when I look up they did E= Q/2e(0.8)^2.
But why not use the 0.100mm because that is the area of the enclosed.
Same with B why did they use 100m and not 0.8m because 0.8 is smaller so it enclosed the charge
No. In that region the expression for the field becomes more complicated (it becomes an integral, if you are familiar with those $$E = \int \frac Q {4\pi\varepsilon_0\, r^2}\ \,dy\, dx \quad $$.)
cf the disc of charge
