Undergrad Christoffel symbols knowing Line Element (check my result)
The discussion centers on calculating non-zero Christoffel symbols from the given line element: ds² = 2x²dx² + y⁴dy² + 2xy²dxdy. Initially, the only non-zero Christoffel symbol identified was Γ^x_{xx} = 1/x. However, after further analysis, it was determined that there was an arithmetic error in the calculations, leading to the correct identification of another non-zero Christoffel symbol: Γ^y_{yy} = 2/y. A suggested change of variables to simplify the calculations involves transforming to coordinates χ = x² and η = y³.
  • Understanding of differential geometry and Christoffel symbols
  • Familiarity with Lagrangian mechanics and Euler-Lagrange equations
  • Knowledge of metric tensors and line elements
  • Ability to perform variable transformations in mathematical expressions
  • Study the derivation of Christoffel symbols from metric tensors in differential geometry
  • Learn about the implications of variable transformations on line elements
  • Explore the application of the Euler-Lagrange equations in classical mechanics
  • Investigate the significance of non-zero Christoffel symbols in geodesic equations
Students and professionals in mathematics, physics, and engineering who are working with differential geometry, particularly those focusing on general relativity or classical mechanics involving Lagrangian formulations.
Confused Physicist
Hi! I'm asked to find all the non-zero Christoffel symbols given the following line element:
ds^2=2x^2dx^2+y^4dy^2+2xy^2dxdy
The result I have obtained is that the only non-zero component of the Christoffel symbols is:
\Gamma^x_{xx}=\frac{1}{x}
Is this correct?
MY PROCEDURE HAS BEEN:
the Lagrangian squared is given by:
\mathcal{L}^2=2x^2\dot{x}^2+y^4\dot{y}^2+2xy^2\dot{x}\dot{y}
where \dot{\quad}\equiv d/d\tau, with \tau being the proper time.
The Euler-Lagrange equations for this Lagrangian are:
<br /> \begin{split}<br /> \frac{d}{d\tau}\Bigg(\frac{\partial\mathcal{L}^2}{\partial{\dot{x}}}\Bigg)-\frac{\partial\mathcal{L}^2}{\partial x}=0\quad\longrightarrow\quad&amp;\frac{d}{d\tau}\Big(4x^2\dot{x}+2xy^2\dot{y}\Big)-4x\dot{x}^2-2y^2\dot{x}\dot{y}=0\\<br /> &amp;8x\dot{x}^2+4x^2\ddot{x}+2y^2\dot{x}\dot{y}+4xy\dot{y}^2+2xy^2\ddot{y}-4x\dot{x}^2-2y^2\dot{x}\dot{y}=0\\<br /> \text{(1)}\quad&amp;2x^2\ddot{x}+xy^2\ddot{y}+2x\dot{x}^2+2xy\dot{y}^2=0\\<br /> \frac{d}{d\tau}\Bigg(\frac{\partial\mathcal{L}^2}{\partial{\dot{y}}}\Bigg)-\frac{\partial\mathcal{L}^2}{\partial y}=0\quad\longrightarrow\quad&amp;\frac{d}{d\tau}\Big(2y^4\dot{y}+2xy^2\dot{x}\Big)-4y^3\dot{y}^2-4xy\dot{x}\dot{y}=0\\<br /> &amp;8y^3\dot{y}^2+2y^4\ddot{y}+2y^2\dot{x}^2+4xy\dot{x}\dot{y}+2xy^2\ddot{x}-4y^3\dot{y}^2-4xy\dot{x}\dot{y}=0\\<br /> \text{(2)}\quad&amp;xy^2\ddot{x}+y^4\ddot{y}+y^2\dot{x}^2+2y^3\dot{y}^2=0<br /> \end{split}<br />
Multiplying equation (1) by y^2/x we obtain: 2xy^2\ddot{x}+y^4\ddot{y}+2y^2\dot{x}^2+2y^3\dot{y}^2=0. Subtracting equation (2) from this result we obtain:
xy^2\ddot{x}+y^2\dot{x}^2=0\quad\longrightarrow\quad \ddot{x}+\frac{1}{x}\dot{x}^2=0
Multiplying equation (2) by 2x/y^2 we obtain: 2x^2\ddot{x}+2xy^2\ddot{y}+2x\dot{x}^2+2xy\dot{y}^2=0.Subtracting equation (1) from this result we obtain:
xy^2\ddot{y}=0\quad\longrightarrow\quad \ddot{y}=0
Knowing that the general expression for the geodesic equation is:
\ddot{x}^\alpha+\Gamma^\alpha_{\beta\gamma}\dot{x}^\beta \dot{x}^\gamma=0
\boxed{\text{the only non-zero Christoffel symbol is therefore: } \Gamma^x_{xx}=\frac{1}{x}}
Please show your work on homework-like questions. Otherwise it is impossible to know where you go wrong (if you do) or confirm that you did things correctly (if you did) and did not come to the correct answer by chance.
Likes Confused Physicist
Your approach is fine. However, your final equation for ##\ddot y## is not. Also, in this particular case, there is a shortcut by a simple change of variables that turns your line element to one with constant coefficients.
Oh, why is my final equation for ##\ddot{y}## not correct?
And what is that change of variables that simplifies the calculation?
Is the solution I have obtained incorrect then?
You have an arithmetic error in your multiplication of (2).
The change of variables should be quite evident from the form of the line element. Hint: You want to make a change to variables ##\chi(x)## and ##\eta(y)## so that the line element takes the form ##ds^2 = A d\chi^2 + B d\chi\, d\eta + C d\eta^2##, where A B and C are constant.
You mean when I multiply (2) by ##2x/y^2##? I'm repeating the process again, but I can't find the mistake...
Ohhhhh okay I've seen the mistake now. The mistake is on equation (2). The ##2y^3\dot{y}^2## should be ##4y^3\dot{y}^2##.
Oh no. That wasn't the mistake. I still can't see what you're pointing out.
FINAL EDIT: Okay, I've seen the mistake. The equation for ##\ddot{y}## should be: ##xy^2\ddot{y}+2xy\dot{y}^2=0##, which gives another non-zero Christoffel symbol: ##\Gamma^y_{yy}=\frac{2}{y}##.
Right. Now try out the coordinate change ##\chi = x^2##, ##\eta = y^3## to see what it does to the metric.
  • · Replies 0 ·
  • · Replies 17 ·
  • · Replies 0 ·
