Mapping Circle to Ellipse with Dilation?
The discussion focuses on the mathematical mapping of a circle to an ellipse through dilation, specifically using the mapping function \( F_{a,b} \) defined as \( (x, y) \to (ax, by) \). The problem, derived from S. Lang's "Basic Mathematics," requires demonstrating that the points \( (u, v) \) satisfying the equation \( \left( \frac{u}{a} \right)^2 + \left( \frac{v}{b} \right)^2 = 1 \) represent the image of a unit circle under this mapping. The solution involves applying the mapping to the circle's equation and recognizing the resulting equation as that of an ellipse, utilizing parametrization with \( u = a \sin t \) and \( v = b \cos t \).
  • Understanding of basic coordinate geometry
  • Familiarity with the concept of dilation in mathematics
  • Knowledge of the equations of circles and ellipses
  • Ability to apply parametrization in mathematical equations
  • Study the properties of ellipses and their equations in detail
  • Learn about the concept of parametrization in geometry
  • Explore the inverse mapping \( F^{-1}_{a,b} \) and its applications
  • Review S. Lang's "Basic Mathematics" for additional context on dilation and mapping
Students studying geometry, mathematics educators teaching dilation and mapping concepts, and anyone interested in the mathematical relationship between circles and ellipses.
Stefk
The problem comes from S. Lang's "Basic mathematics", chapter 7, §1:
"Consider the following generalization of a dilation. Let ##a > 0, b > 0##. To each point ##(x, y)## of the plane, associate the point ##(ax, by)##. Thus we stretch the x-coordinate by ##a## and the y-coordinate by ##b##. This association is a mapping which we may denote by ##F_{a,b}##.
Show that the set of points ##(u, v)## satisfying the equation $$\left( \frac u a \right)^2 + \left( \frac v b \right)^2 = 1$$ is the image of the circle of radius 1 centered at ##O## under the map ##F_{a,b}##."
Equation of a circle of radius ##r## centered at ##(a, b)##: $$(x - a)^2 + (y - b)^2 = r^2$$
Equation of a circle of radius ##r## centered at the origin: $$x^2 + y^2 = r^2$$
Equation of a circle of radius 1 centered at the origin: $$x^2 + y^2 = 1$$
[/B]
I've spent quite some time on this problem and I still can't see how to solve it. I understand by subsequent indications and further reading on wikipedia that the equation is the cartesian equation of an ellipse and that the exercise is a way of viewing the ellipse as an irregularly dilated or stretched circle. However, I don't see any rigorous, algebraic way of coming to that equation from the circle equation using the ##F_{a,b}## mapping, nor the other way around (e.g. using an inverse mapping ##F^{-1}_{a,b}##). Applying the mapping to ##u## and ##v## on the left-hand side doesn't even seem to make sense. I might be missing something obvious...
Thanks in advance for your help.
PS: there isn't any development on ellipses in Lang's book (at least not in the part where the exercise comes from or before) so a solution can't rely on anything else that what was stated in the problem, except basic notions of coordinates, distance between points and Pythagora's theorem.
Use parametrisation.
Let u = a sin t and v = b cos t.
These are the relevant bits.
The first bit means, whenever you see ##x##, write ##ax##, whenever you see ##y## write ##by## (you can write it ##x \to ax## and ##y \to by## or something like that).
Now apply that to the second bit quoted above and take it from there.
  • · Replies 62 ·
10K
  • · Replies 16 ·
