Circuit design with 2900 Hz buzzer and thin wire sensor
2 replies · 3K views · last reply
Jkruzz
Hi guys, I've been using your forums for quite a while to help reinforce my physics principles, and only just made my account. I wanted to know if there were any electrical engineers that would be willing to assist me with some guidance in a small design challenge.
Here are the goals
Design a circuit with no moving parts (i.e., no switches) that
(1) will effectively monitor the integrity of the thin wire sensor, and
(2) it will set off the buzzer if the window is breached (and hence the thin wire as well.)2. Relevant Constraints
12 1.5V AAA batteries
1000 1Ω resistors
2900 Hz piezoelectric buzzer
- draws 15 mA at 6 V
- Minimum(Voltage) 6V and maximum 28V to operate buzzer
I already have a rough model, but it does not provide the required voltage when simulated in Pspice... I am pretty sure my methodology is completely wrong
Ideally, the least parts should be used.
If anyone is willing to help me with some guidance for this minor project it would be greatly appreciated! PM me for more details if interested
Here are the goals
1000 1Ω resistors
Hi Jkruzz, Welcome to Physics Forums.
Can you post a circuit diagram corresponding to your rough model, and perhaps outline its 'theory of operation' and some relevant calculations?
Welcome to the PF.
Posts about this project should be in the open forum, and not carried out via PM.
And are you sure that is all the materials you are allowed to use? No transistor? How long is the circuit expected to last on battery power before the batteries need to be replaced?
