Circuits question, series vs parallel
5 replies · 2K views
Falcon99
There are 2 circuits.
A:
-A series circuit
Components:
-Motor
-Filament lamp
-Resistor
B:
-A parallel circuit
Components:
-Motor
-Filament lamp
-Resistor
-Each component is in a separate parallel circuit
Question)Explain why the power of the motor is lower in the circuit shown in A than the circuit shown in B.
V=IR
P=VI
P=I^2R
[/B]
My solution of to why circuit A has a lower power is because of the fact that we have less pd as voltage is shared out but current stays constant P=VI ,we would also know that resistance is cumualtive and so would decrease total power as P=I^2R . However in circuit B it is parallel and so current is shared out and voltage stays constant P=VI, but in parallel resistance decreases as more resistance is added ,so by P=I^2R circuit B has more power . Is this a strong enough explanation for the question?[/B]
A:
-A series circuit
Components:
-Motor
-Filament lamp
-Resistor
B:
-A parallel circuit
Components:
-Motor
-Filament lamp
-Resistor
V=IR
P=VI
P=I^2R
[/B]
I would say no. The explanation is not very consistent and you have random formulas interjected into sentences that do not justify the claims you are making. For example what is ##R## in the equations? Is it the resistance of the light bulb, the motor, or the whole circuit?
I would suggest that you actually find a mathematical expression for the power dissipated by the motor in each circuit and show that one is less than the other.
Let'sthink said:
Better to use P = V^2/Req.
Sorry, the correct equation is P = V^2/(2Req)
I would suggest that you should not look for a formula. Draw the circuit diagram for each case, use standard rules of circuits to find the current in the motor, then use the formula for the power in the motor, and then compare the two. Using a formula to start with is never a good idea.
