Circular Motion and Tension in a string
The discussion centers on calculating the tension in a string when a ball of mass 4.775 kg swings downwards through an angle of 45 degrees. The initial approach involved using Newton's second law and energy conservation principles, but the calculations were incorrect. The correct formula for tension is T = mg sin(θ) + m(v²/L), where θ is the angle of displacement. The community suggests simplifying the problem by applying conservation of energy to find the velocity as a function of θ instead of solving a differential equation.
  • Understanding of circular motion dynamics
  • Familiarity with Newton's second law
  • Knowledge of energy conservation principles
  • Basic trigonometry for angle calculations
  • Study the application of Newton's second law in circular motion
  • Learn about energy conservation in mechanical systems
  • Explore the derivation of tension in pendulum systems
  • Investigate the effects of angle on tension and velocity in circular motion
Students studying physics, particularly those focusing on dynamics and circular motion, as well as educators seeking to clarify concepts related to tension in strings and energy conservation.
Sdarcy
Okay, I have given this a go but its been 2 years since I've done any dynamics so I think I've done something stupid...
A ball is attached horizontally by a string of length L to a central point C. The mass, m, of the ball is 4.775kg. It is released from rest and allowed to swing downwards. What is the tension in the string (in N) when the ball has fallen through 45 degrees.
This is what I've done so far:
\sumF_{}n = ma_{}n
T- m sin\alpha = m/g (v^{}2/L)
T = m(sin\alpha + v^{}2/gL)
\sumF_{}t = ma_{}t
m cos\alpha = m/g a_{}t
a_{}t = g cos\alpha
vdv = a_{}t ds
ds = L d\alpha
vdv = a_{}t L \alpha
vdv = g L cos\alpha d\alpha
then integrate that equation
v = \sqrt{}2gl(sin\alpha - sin\alpha0)
T = m(3 sin \alpha - 2 sin \alpha0)
= 4.775[3sin(45) - 2sin(0)]
= 10.13N
Which is apparently very, very wrong.
Not sure what I've stuffed up, but help would REALLY be appreciated. Thanks.
I think that you have over complicated this question somewhat. Start by writing down the net horizontal and vertical forces acting on the ball.
Lets pretend I'm stupid (which I am) and that I don't know anything about dynamics (which I currently don't), can you explain more clearly what you mean? :D
Thanks
Thanks
Whilst you seem to heave already put a lot of work in I don't mind doing a bit of work for you ... just this once :wink:.
I'll admit to making a mistake in my previous post, I should have said radial and tangential components rather that horizontal and vertical. So for the radial components:
\sum F_r = T - mg\sin\theta
As you correctly have. Now since the ball is following a circular path and applying Newton's second law we obtain:
T - mg\sin\theta = m\frac{v^2}{L}
Now from here, rather than attempting to solve a differential equation, it would be much more straight forward to apply conservation of energy to determine the velocity as a function of theta. Do you follow?
On a related point, you should note the mistake in going from the first line to the second line in your OP:
Sdarcy said:
T- m sin\alpha = m/g (v^2 /L)
The first term on the LHS should also be divided by a factor of g.
  • · Replies 36 ·
