Why is the photon's mass zero in classical equations for light?
  • Context: Graduate
  • Thread starter Thread starter JulianM
    Classical Light
The discussion centers on the concept of the photon's mass being zero in classical equations for light. The equation E² = (mc²)² + (cp)² demonstrates that if light's energy E is equal to cp, then the invariant mass m must be zero. Participants clarify that classical momentum equations, such as p = mv, are not applicable in relativistic contexts, where the correct momentum for a photon is given by p = hf/c. The conversation emphasizes the distinction between classical and relativistic physics, asserting that classical equations are approximations that fail for massless particles like photons.
  • Understanding of special relativity and its equations
  • Familiarity with the concepts of energy and momentum in physics
  • Knowledge of classical mechanics and its limitations
  • Basic grasp of electromagnetic wave behavior
  • Study the implications of E² = (pc)² + (mc²)² in relativistic physics
  • Learn about the concept of invariant mass and its applications
  • Explore the differences between classical and relativistic momentum equations
  • Investigate the behavior of light in various media and its dispersion relations
Physics students, educators, and professionals interested in the principles of relativity, electromagnetic theory, and the nature of light. This discussion is particularly beneficial for those seeking to deepen their understanding of the relationship between mass, energy, and momentum in both classical and modern physics contexts.
JulianM
Mentor's note: this thread has been forked from https://www.physicsforums.com/threads/why-the-photon-has-no-mass.899792/#post-5912751
lightarrow said:
The correct equation, that is, the one which is always correct in special relativity, is:
E^2 = (mc^2)^2 + (cp)^2 (1)
p = momentum.
We know from classical electrodynamics that light's energy E is equal to cp. Then, from (1) you see that m must be zero.
lightarrow
But momentum = mass x velocity so that part of the equation is E2 = c.(mv)
If the mass is zero then that formulation also yields zero energy (which we know is not true)
Science news on Phys.org
This definition is based on another concept of mass. Today "mass" means invariant mass and that results in another equation for momentum.
The momentum of a photon is given by ##p = hf/c##. Not by ##p = mv##.
In fact, ##p = mv## is a non-relativistic approximation of the momentum of a massive particle. The correct equation is:
##p = \gamma mv##, where ##\gamma = \frac{1}{\sqrt{1 - v^2/c^2}}##
So lightarrow was wrong?
No, he was and is still right.
Regardless of whether you include gamma this equation still contains mass.
Anything multiplied by zero is still zero.
For a photon ##E = cp##. So, he is right and you are not.
##p = mv##, as I have already explained, is a classical equation for the momentum of a particle that is not valid in relativity - for any particle, massless or otherwise.
JulianM said:
He said E = cp
I said p = mv
therefore E = c (mv)
Again, this "m" is an outdated concept of mass. It dates back to classical mechanics and is not used anymore because it is frame dependent in relativity. With the modern concept of mass (invariant mass) the equations for momentum and energy are
p = \frac{{m \cdot v}}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}
E = \frac{{m \cdot c^2 }}{{\sqrt {1 - \frac{{v^2 }}{{c^2 }}} }}
Of course they cannot be used for photons (because v=c), but they result in equations like
p = \frac{{E \cdot v}}{{c^2 }}
and
E^2 = m^2 \cdot c^4 + p^2 c^2
which are valid for v=c and m=0.
That equation is for a massive particle. It doesn't apply for a photon. In fact, it is not ##0## for a photon, it is undefined. Since the photon has zero mass and speed ##c## you would get:
##p = \frac{mc}{0} = \frac00##
Which is undefined. So, you have to look elsewhere for the equation that gives the momentum of a photon.
PeroK said:
This is the problem with asking something like "was lightarrow wrong"? How was I supposed to know what you thought was wrong? So, I read his post and found an error. Which I quoted above. He said:
Which is clearly a typographic error. That's where ##p = cp## came from.
So, back to your real question.
##p = mv##, as I have already explained, is a classical equation for the momentum of a particle that is not valid in relativity.
So what is the equation in relativity? It can't be just multiplying momentum by gamma as PeroK did (above). That still gives zero energy.
The general equation for momentum is:
##p^2c^2 = E^2 - m^2c^4##
That works for both massive and massless particles.
For a massive particle the energy is ##E = \gamma mc^2##
And, for a photon the energy is ##E = hf##.
Which is undefined.
But the limit for ##v \to c## (and therefore ##m \to 0##) is defined.
PeroK said:
The general equation for momentum is:That works for both massive and massless particles.
How does
work for a massless particle if p= m.v
That would give (for v = c)
( mc^2).c^2 = E^2 - m^2.c^4
is equivalent to
E^2 = m^2.c^4 - m^2.c^4
There's something wrong, surely it cannot apply to a massless particle which posses energy
JulianM said:
How does
is equivalent to
What will it take for you to accept that ##p = mv## is not a valid equation?
Again, as you have been told repeatedly, p = mv is not a valid equation relativistically. Repeating the same mistake does not make it true.
Well now you have me very confused. How do we know when to apply relativistic equations or not?
For a massless particle, you have no choice. For massive particles, the relativistic equation is always true to but the slower the particle is, the less difference there is between the results of the classical equation and the relativistic equation. At human-scale speeds, the classical equation always gives results that are useful.
In principle, the relativistic equations are always valid and the classical equations are an approximation. If that approximation is good enough, then you can apply the classical equations.
If the velocities involved are a significant proportion of the speed of light, then you definitely need the relativistic equations.
In practice, it depends how accurate you need your answer. Time calculations for GPS satellites must be so accurate that relativistic equations are needed despite the modest speeds. But, normal engineering calculations are usually more than accurate enough with classical equations.
No, in THIS case, momentum is defined via the wavenumber, i.e.
p=ħk
So there is no requirement for a "mass" here.
Zz.
You can always apply the relativistic equations, and you will always get the right answer. They're more exact than the non-relativistic ones.
However, the relativistic equations are also more complicated and using them is more work, so we don't use them when the relativistic effects are small enough to ignore. For example: what is the kinetic energy and the momentum of a one-kilogram mass moving at ten meters per second? Try calculating that using the classical formulas and using the relativistic ones. Which was more work? And what difference did it make?
The classical formulas can be used any time the speeds involved are small compared with the speed of light (equivalently, ##\gamma## is so close to 1 that you're OK with the approximation ##\gamma=1##). Clearly this is not the case for particles traveling at the speed of light, so you know that the classical formulas can't be used here.
What should I use then for light which has been slowed to "non-relativistic" velocities? I presume that only relativistic equations would still have to apply?
The speed of light is always ##c##. You can't slow it down.
Sure you can. C is only for a vacuum.
You are trying to open an entirely different can of worms here. The dispersion relation for light in a medium is not the same as that in vacuum. You really cannot say that light in a medium is massless.
That's a very different scenario. In a medium photons interact with the medium, are absorbed and may be re-emitted. That's what causes the apparent change in speed. You can't directly use equations for undisturbed motion in this case.
I must say that I really dislike this quite popular heuristic. I do not think it adequately describes what is going on and leads to misconceptions and misunderstandings.
Either way, I generally recommend staying away from ”photons” when discussing classical relativity and instead look at the dispersion relation of plane EM waves in the medium.
##\vec{p}=\left(\frac{E}{c^2}\right) \vec{v}##
Your confusion is over when we can use equations that apply to massive particles versus equations that apply to massless particles. The equation I wrote above applies to both, as does the one previously mentioned in this thread: ##E^2=(pc)^2+(mc^2)^2##.
The equation ##\vec{p}=\gamma m\vec{v}## applies only to massive particles. For low speeds ##\gamma \approx 1## and we can write ##\vec{p}=m \vec{v}##.
Up until now we have been discussing a single massless photon moving at speed ##c## through a vacuum. Once you start looking at collections of photons you see that the collection can and usually does have mass. Having a beam of light scatter as it passes through a medium involves the photons interacting with the atoms that make up the medium. You can try to understand that, but modelling the light as a collection of massive particles moving at speeds less than ##c## will not work in the sense that the model will not be consistent with the way we see light actually behaving.
Furthermore, the CHANGE in the apparent speed of light in a medium is because we tend to measure the group velocity of light! This automatically means that we measure not the speed of a photon, but rather the speed of a collection of LARGE number of photons, which we collectively call "light" or EM wave. This is what we typically measure as the speed of light.
Zz.
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 19 ·
