Classical Mechanics - Tranformations
13 replies · 2K views · last reply
teme92
Consider a transformation to a relatively uniformly moving frame of reference, where each position vector ri is replaced by rli = ri − vt. (Here v is a constant, the relative velocity of the two frames.) How does a relative position vector rij transform? How do momenta and forces transform? Show explicitly that if equations (1.1) to (1.4) hold in the original frame, then they also hold in the new one.
(1.1) pli = miai = Fi
(1.2) Fi = Fi1 + Fi2 + · · · + FiN = ∑Fij
(1.3) Fji = -Fij
(1.4) Fij = r^ijf(rij)
The r^ is supposed to be the unit vector but I can't get r hat to work.
p=mv
F=ma
So I said rij = ri - rj
As rli = ri − vt, rearranged and got ri on its own and then subbed into rij = ri - rj, giving:
rij = rli - rj +vt
I'm confused about the next part.
v is relative velocity so: v = vi - vj
What does this mean for the momenta and the forces? Any help would be much appreciated.
##\hat{r}#[/color]# -> ##\hat{r}##
Fine so far.
Now the question asks you to find r'ij.
rij = rli - rj +vt
That statement is true, but not helpful - it mixes coordinates from one frame with coordinates from the other frame.
No, you can (and should) look at the absolute velocity in this frame. The position is the only part of the question where relative quantities are looked at.
r'ij = r'i - r'j = ri - vt -(rj - vt)
I'm not sure about the r'j as it doesn't specifically say what it is in the question.
i or j as index does not matter, that is just an arbitrary letter.
You can simplify the right side now. The answer will get really short.
So vt cancels and I'm left with:
r'ij = ri - rj
which is the same as rij. So there's no change?
So does this mean there is no change in the momenta or forces also then?
Well p=mv: m is constant and seeing as r doesn't change the derivative which is velocity will be the same.
F=ma: once again m is constant and a is the second derivative of r, so there should be no change
r (the position coordinate) does change, you directly see this in the problem statement.
What you calculated before was the relative position of two objects.
Ok so going on pi = mivi
v'i= vi - v
but v = vi - vj
so v'i= vi - (vi - vj)
v'i = vj
so p=mvj
Is this correct? And if it is do I just differentiate again to get acceleration for F=ma?
teme92 said:
but v = vi - vj
What is vj?
And where is p'?
That will work, but you have to find the correct p' first.
