This implies that the circulation around the ellipse ##C## is also zero.
  • Thread starter Thread starter Differentiate1
    Circulation
The circulation of the vector field F = y²z³i + 2xyz³j + 3xy²z²k around the ellipse C, defined by the intersection of the plane 2x + 3y - z = 0 and the cylinder x² + y² = 16, is confirmed to be zero. This conclusion is derived from the fact that the curl of F is zero, indicating that F is a conservative vector field. According to Stokes' theorem, the line integral of a conservative vector field around any closed path is zero, validating the result.
  • Understanding of vector calculus, specifically line integrals and curl.
  • Familiarity with Stokes' theorem and its applications.
  • Knowledge of parametric equations for curves and surfaces.
  • Basic proficiency in manipulating vector fields and performing vector operations.
  • Study the application of Stokes' theorem in various contexts.
  • Learn how to compute the curl of vector fields in three dimensions.
  • Explore conservative vector fields and their properties in depth.
  • Practice solving line integrals using parametric representations of curves.
Students and professionals in mathematics, physics, and engineering who are working with vector fields, particularly in the context of fluid dynamics and electromagnetism.
Differentiate1
F = y2z3i + 2xyz3j +3xy2z2k
Find the circulation of F in the clockwise direction as seen from above, around the ellipse C in which the plane
2x + 3y - z = 0 meets the cylinder x2 + y2 = 16
∫ F (dot) dr = ∫∫ (∇xF) (dot) k dA
z = 2x + 3y ==> z = (8cosθ + 12sinθ)
r(θ) = 4cosθi + 4sinθj + (8cosθ + 12sinθ)k
dr = -4sinθi + 4cosθj + (-8sinθ + 12cosθ)k
I'm thinking of substituting the values from r(θ) to F, but that would appear to be too much work due to the third powers and having to multiply the results together after substituting.
However, the other equation ∫∫ (∇xF) (dot) k dA appears to be easier. I computed the curl of F and got 0, which is my answer at this time. Instead of having to substitute the values of r(θ) to F (which would be a pain), the curl of F shows that the circulation is 0.
I need confirmation whether this is true and the answer, 0 circulation is correct.
Thanks in advance.
##\vec F## is indeed conservative since ##\text{curl}(\vec F) = 0##.
The line integral of a conservative vector field around any closed path (within the domain) is zero.
Another cool way to see this is to use Stokes' theorem.
$$\oint_C \vec F \cdot d \vec r = \iint_S \text{curl}(\vec F) \cdot d \vec S$$
The intersection of the plane with the cylinder creates a piecewise smooth surface ##S## comprised of a slanted top surface ##S_1##, a cylindrical shell ##S_2##, and a circular bottom region ##S_3## bounded by ##z = 0##. The net flux out of this surface is zero:
$$\oint_C \vec F \cdot d \vec r = \iint_S \text{curl}(\vec F) \cdot d \vec S = \iint_{S_1} \text{curl}(\vec F) \cdot d \vec S_1 + \iint_{S_2} \text{curl}(\vec F) \cdot d \vec S_2 + \iint_{S_3} \text{curl}(\vec F) \cdot d \vec S_3 = 0$$
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
