Clockwise moments = anti-clockwise moments
  • Thread starter Thread starter lemon
    Moments
15 replies · 6K views · last reply
lemon
1. The rod shown in the diagram(mass 10g, length 100cm) is in equilibrium. Find the position of the pivot and the magnitude of the supporting force F.
2.clockwise moments = anti-clockwise moments
3. I'm not so sure here. I have unknown distances.
Please see file attachment 2 - Distances 1-4.
dtotal=100cm
d1=30cm
d2=20cm from 40g object to the (Weight force component) centre of rod.
d3 and d4 are unknown
(0.01xd1)+[0.04x(d2+(50-d4))]+(0.01xd3)=0.06xd4
(0.01x0.30)+[0.04x(0.20+(50-d4))]+(0.01xd3)=0.06xd4
So I have a couple of d-unknowns. Do I solve for one then plug back into get the other?
Can't see how this would work with [0.04x(d2+(50-d4))] this in the equation.
Please advise?
  • rod012.pdf
    rod012.pdf
The first image is not for this problem - please ignore this.
the .pdf file is correct.
I am uploading the correct image here in a moment
ok.
Ahh! So much work to get through :cry:
Right - so i don't have unknown distances after all:
I should start again:
3.
(weight1x30cm)+(weight2x35cm)+(weightGravityx15cm)+(weight3x35cm)
F=(.65x0.01)+(0.35x0.04)+(0.10x0.15)+(0.35x0.06)=0.0565N
Could someone let me know if this is the correct way to calculate this problem please?
lemon said:
ok.
3.
I am not sure where you are getting the figure .35 from... When you sum moments and set their sum equal to zero for equilibrium, you can sum moments about any convenient point. Try summing moments about the right end of the beam, and solve for the distance of the pivot from the right end...Note that your mass is in grams, which should be converted to weight units...and the value of F you can get from looking at the net force in the y direction...
Hi:
The 15cm was the distance of the weight of the beam from the center position.
(10gx100cm)+(40gx70cm)-(Fx35cm)=0
(0.01x1.0)+(0.04x0.7)-(Fx0.35)=0
0.35F=0.038
0.038/0.35=0.11N (2s.f.)
Don't I also need to take into account the 60g?
lemon said:
Hi:
0.35F=0.038
Am I looking at the correct figure? The resultant of the 10g beam's weight acts at its center, or 50 cm from one end. The pivot force, F, acts at an unknown distance from the right end. I don't know where you get 35 cm. First find F from Newton 1 by summing vertical forces = 0. And then do the moment thing, but don't forget to include the moment from the beam's weight. Also, when summing moments about the right end, the 60 g mass has no moment arm, so its moment about the right end is 0.
To find the force:
(10gx100cm)+(40gx70cm)+(10gx50cm)-x=0
x=1+0.028+0.05=1.078N
To find the pivot:
Clockwise moments = Anti-clockwise moments
1.078=Fxd
F=1.078-d
1.078=(1.078-d)xd
1.078/1.078-d=d
d=0.5 This seems wrong (algebra booboo)?
Therefore
Fx0.5=1.078
F=1.078/0.5=2.158N
Nah, to find the Force, first forget about moments. Just use sum of forces in y direction = 0, per Newton's first law for objects in equilibrium. Note that you have five forces involved: four of them are given and act down, and the fifth is unknown, which is the pivot force, F, acting up on the beam. Solve for it. Then sum moments to determine X.
You mean the sum of the forces and not the forces multiplied by distances? Just the four weights, mg?
(10gx10N)+(40gx10N)+(10gx10N)+(60gx10N)-x=0
10+40+10+60-x=0
x=120N
10+40+10+60-x=0
x=120N
Yes, but don't use x = 120 N, use F= 120 N. Othewise, you'll really get confused when you try to solve the distance x where F acts.
Arre you familiar with Newton's 1st law, sum of forces =0?? That's where the 120 N comes from; 120 N acting down, therefore 120N must act up from F, which is the sole support.
Now you can sum moments to solve for the distance x where the pivot must be located.
I know Newtons first law to be:
If there is no resultant force acting on an object,
if it is at rest, it will stay at rest,
if it is moving, it keeps moving at a constant velocity (at constant speed in a straight line).
I'm not familiar with, sum of forces =0. I guess that from what I wrote above it means that if a body is at rest, the sum of the forces must equal 0 because it will remain in that state unless a resultant force acts upon it. It remains in equilibrium. And the same applies if it is moving.
Taking moments about 60g
(10gx100cm)+(40gx70cm)=(120N)(x)
(0.01x1.0)(0.04x0.7)=120x
0.00028=120x
0.00028/120=0.000002333m
Well. That doesn't seem right
So:
sum of clockwise moments = sum of anti-clockwise moments
(10gx50cm)+(40gx20cm)+(120N)(x)=(60gx50cm)
0.005+0.008+120x=0.03
0.013+120x=0.03
120x=0.017
x=0.00015m (2s.f.)
Well, that seems a little short too :frown:
lemon said:
should i be taking moments about the pivot point?
You can take moments about any point you want , but choose a convenient one to simplify your calculations. You are very careless in your work...you forgot to include the moment from the weight of the rod's 10 gram mass,and you forgot to convert all mass units into weight units, and you multiplied when you should have added. You can take moments about the right end of the rod, or the left end of the rod, or the center of the rod, or even the center of the moon for that matter; no matter what, the location of the pivot will always be the same. Try it again, summing moments about the right end, and please don't forget what you missed last time (convert mass to weight, watch your math, don't forget the weight of the beam which acts at the center of the rod...)...
Sorry.
(0.1x100)+(0.4x70)+(0.1x50)=120x
10+28+5=120x
43=120x
x=0.36 (2.s.f.)
36.0cm
This seems better. In this type of calculation where we are given the measurements in cm, should I change them to meter just to change them back to cm at the end. It seems a waste of effort but our school is always saying we should change to meters first.
lemon said:
Sorry.
10+28+5=120x
43=120x
x=0.36 (2.s.f.)
36.0cm
Well, lemon, this time it was me who made the math errror, sorry,it happens to the best of us. I seldom use the metric system, so it confuses the heck out of me with all its decimal points, and because we just don't use it here in the USA. Anyway, no excuse, an objectwith a mass of 10 grams has a mass of .010 kg, which has a weight of 0.1 N; thus the force of the pivot on the beam is 1.2N, not 120 N as originally stated. So when you do your math, leaving the units of distance in cm, the result is x =36 cm, as measured from the right end of the rod. Now you could convert everything into meters, and end up with x = 0.36 m, your choice, then give the answer in cm by multiplying by 100. I find it odd that you were using x =35cm way back in the beginning before you did any calculations, which is more or less the correct answer, leading me to believe that you were given that value by a friend or book answer at the start :confused:, but anyway, your numbers look good now. Go metric!
Hi:
Thanks PhantomJay.
And no. There are no answers available to me. Only the ones I can come to here. This is a project to be handed in this Friday morning, with much still to do :(
