Why does the characteristic function not converge in the L1 space?
  • Context: Graduate
  • Thread starter Thread starter member 428835
    Ball Closed Compact
The discussion centers on the non-compactness of the closed ball in the L1 space, specifically L1[0,1]. A sequence of functions g_n defined as g_n(x) = x^n is bounded in L1, yet it lacks a convergent subsequence due to pointwise convergence issues at x=1. The counterexample f_n = 2^n * 1_[0,1/2^n] illustrates that while the sequence is bounded in L1, the distance between distinct functions remains bounded away from zero, preventing convergence. The Riesz theorem is also referenced, confirming that closed unit balls are not compact in infinite-dimensional Banach spaces.
  • Understanding of L1 space and its properties
  • Familiarity with concepts of sequential compactness and convergence
  • Knowledge of the Riesz theorem and its implications in functional analysis
  • Basic understanding of characteristic functions and their notation
  • Study the Riesz theorem in detail, particularly its proof and applications in Banach spaces
  • Explore the differences between convergence in L1 and C spaces
  • Investigate the properties of characteristic functions and their role in measure theory
  • Learn about Cauchy sequences and their significance in metric spaces
Mathematicians, particularly those specializing in functional analysis, graduate students studying measure theory, and anyone interested in the properties of L1 spaces and convergence issues in infinite-dimensional spaces.
member 428835
Hi PF!
When proving a closed ball in ##L_1[0,1]## is not compact, I came across a proof, which states it is enough to prove that the space is not sequentially compact. Counter example: consider the sequence of functions ##g_n:x \mapsto x^n##. The sequence is bounded as for all ##n\in \mathbb N, \|g_n\|=1##. If ##(g_n)## would have a convergent subsequence, the subsequence would converge pointwise to the function equal to 0 on ##[0,1)## and to 1 at 1. As this function is not continuous, ##(g_n)## cannot have a subsequence converging to a map in ##L_1[0,1]##.
Why is it that because ##x=1## does not converge to the same thing as ##x\in[0,1)## this implies there are no subsequences converging to a map in this space?
Original proof here (second proof):
http://www.mathcounterexamples.net/a-non-compact-closed-ball/
I think you may have misread the article you linked. It seems as if the space there is not L1[0,1], but C[0,1]. I.e. this sequence does converge in L1 but not in C, i.e. it has an integrable limit but not a continuous one. You might be interested in the Riesz theorem mentioned there, that the closed unit ball is not compact in any infinite dimensional Banach space. This theorem is proved in an elementary way in chapter V, p. 109, of Foundations of Modern Analysis, by Jean Dieudonne'.
By the way, the first tipoff was that an L1 convergent sequence need not have a pointwise convergent subsequence, but only one that converges almost everywhere. i.e. the integral cannot detect erratic behavior at a single point.
Thanks for replying. I actually found the theorem you've mentioned, but it is a little more advanced than I am comfortable with. I did track down Reisz theorem in a more readable form here (see first four lines of the converse):
https://en.wikipedia.org/wiki/Riesz's_lemma
But even this I don't fully track. I did see a counter example ##f_n = 2^n \textbf{1}_{[0,1/2^n]}##. Can you explain to me how this counter example works though?
joshmccraney said:
But even this I don't fully track. I did see a counter example fn=2n1[0,1/2n]f_n = 2^n \textbf{1}_{[0,1/2^n]}. Can you explain to me how this counter example works though?
this sequence is bounded in ##L^1[0,1]## ,on the other hand ##\|f_i-f_j\|_{L^1[0,1]}\ge const>0,\quad i\ne j## so that this sequence does not contain a convergent subsequence
Isn't this sequence unbounded though? ##\lim_{n\to \infty}f_n = \lim_{n\to \infty}2^n \textbf{1}_{[0,1/2^n]}## and since ##2^n \to \infty##, how is this bounded?
you must remember again what the notion of size is in L1, namely it is the size of the integral, so the point here is that the integrals are bounded. this is the same issue that arose above, of confusing the norms in C and in L1, i.e. the maximum value of |f|, versus the integral of |f|.
Thanks! So it seems obvious ##\| f_n(x) \|= 1## if ##x \in [0,1/2^n]##. But why does ##\|f_i-f_j \|> 0## imply no subsequence converges in ##[0,1]##?
that is not what was said. he said that difference is not just positive but bounded below by a positive constant. since for a sequence no two of whose terms ever get close, the same holds for any subsequence, thus no subsequence is even cauchy.
Brilliant! And thanks!
So let me ask, what does the bold 1 denote? I just assumed ##f_n = 2^n## if ##x \in [0,1/2^n]## else ##f_n = 0##.
Another standard example is the unit ball in Hilbert space with vertices ## e_i = \delta_i^j ## . Then ## || e_i- e_j ||> \sqrt 2 ## and no convergent subsequence. ##||a-b||^2=<a-b,a-b>=2 ## . So no subsequence will be Cauchy. Note that the result on the equivalence with not having a convergent subsequence only applies to metric spaces.
I believe you are right. I.e. that the bold 1 denotes the characteristic function of the following subset, i.e. the function that equals 1 on that set and zero elsewhere. To me a more common notation is a "chi" (for characteristic) rather than a "1".
Yes, I have seen it used this way too, as the characteristic function.
