russ_watters
Mentor
- 23,799
- 11,237
So, this question piqued my interest enough that I'm going to geek-out on it a bit. For those of you who don't know, I'm an HVAC/energy engineer and my specialty, if I can be said to have one, is lab ventilation. So I'm constantly thinking about issues like this one. Further, I'm always looking for an excuse to buy a new tax-deductable tool for my work, so I bought a carbon dioxide logger (also logs temp and humidity) to test the issue.
Background/Standards:
OSHA TWA-PEL: .5%/5,000 ppm (8-hour Time-Weighted Average Personnel Exposure Limit)
Noticeable breathing elevation/headaches: 2%
Normal Spacecraft: 0.5%
Apollo 13: "Approaching 2%"
5,000 ppm is the relevant limit, but I include the other information for reference.
Setup:
I will be driving my normal routes to and from work (as well as others), with the CO2/Temp/Humidity logger in the passenger seat, at 15 second intervals. My car is a Kia Optima SX (interior volume: 3.33 cubic meters/118 cubic feet), which has automatic climate control. I keep it in semi-manual mode, with only the temperature controlled automatically. I'll do a humidity purge (open all the windows for a few seconds) at the start of each test. Air will be supplied to the front and floor vents: the climate control will not allow the windshield vents open without the outside air damper being open. I'll conduct full-length trials with the OA damper open and closed and note any potential upset conditions when they occur (such as getting stuck behind a school bus). Drive times vary from 30-60 minutes and I have two different routes, to work is all "city" driving, home is a mixture of open and congested highway. I'll be alone in the car for all trials.
Hypotheses:
1. My primary hypothesis is that at no time will a closed OA damper result in CO2 levels exceeding the OSHA PEL of 5,000 ppm. My prediction is a steady state of 300-500 ppm above ambient (reached within the time limit of the test), but it may be higher in slow speed driving and/or lower in high speed driving.
2. My secondary hypothesis is that being behind a bus or truck with a low exhaust and the OA damper open will have a substantial impact on concentrations, approaching and perhaps even exceeding the OSHA PEL for short periods of time. Even now, when I have the OA damper open and get behind a bus, I close it. For the test, I'll resist that urge.
Limitations:
Humidity will be a significant limitation and this test would be better in the summer, when air conditioning removes it. I checked, and my car will not allow the air conditioning to run in the winter, even in manual mode. So I may have to abort some of the tests. Adding more people would add more CO2, but in winter, having 4 people in a car will cause condensation in seconds, so it isn't possible. If the steady-state CO2 level is too low with just me in the car or if I can't keep the OA damper closed long enough for SS to be approached, the test may have to be repeated in the summer.
Setup:
Hypotheses:
Limitations:
