Creating a Double Precision Matlab Function from Scratch
The discussion focuses on creating a MATLAB function to evaluate f(x) = (e^x - x - 1) / (x^2) using only double precision and without built-in functions. Participants suggest using the Maclaurin series to approximate e^x, emphasizing the importance of understanding the function's behavior by plotting it first. The condition |x| < 1 is noted as a guideline rather than a strict requirement for testing inputs. There is a recommendation to use a while loop for implementing the Maclaurin series to manage truncation errors effectively. The conversation highlights the need for careful mathematical simplification before coding the function.
ver_mathstats
Write a matlab function that evaluates f(x) as accurately as possible when |x|<1. You can only use double precision and must not use any matlab built in functions,
The function we are required to code is got (f(x)=e^x-x-1)/(x^2)
I am confused at how to code this without using any of matlab's already built in functions except for using double. Is this question just asking me to write out the function and then make sure it's double precision?
So we're not allowed to give direct answers on this forum, but I would suggest starting off to plot the function on a graphing calculator and see how it looks in general. This is just to get you started to understand how this function behaves overall.
For example, plotting it on something like Symbolab could help you:
https://www.symbolab.com/graphing-calculatorNow, let's start with the "|x| <1" condition. Since you can't use a built-in function from MATLAB, how would you be able to implement this in MATLAB? Essentially, what this is asking is to take in all inputs of x in which the absolute value of that input is less than "1". Think of what "condition" means when you're writing code.
ver_mathstats said:
Homework Statement:: Write a MATLAB function that evaluates f(x) as accurately as possible when |x|<1. You can only use double precision and must not use any MATLAB built in functions,
Relevant Equations:: The function we are required to code is got (f(x)=e^x-x-1)/(x^2)
No. These are two separate requirements.
  • Built-in MATLAB functions are not allowed.
  • Calculations are to be done using double precision.
Since you aren't allowed to use exp(), it seems to me that the first requirement presumes that you know about the Maclaurin series for ##e^x##.
Likes pbuk
Okay, so we are essentially replacing e^x with its Maclaurin series and then when you say condition, you mean writing out the conditional statements?
I'm afraid @ammarb32 may be confusing you: the ## |x|<1 ## condition is only there to make it easier for you (can you think why?), it is not something you need to test for. I should ignore that post and carry on with rewriting ## f(x) ## using the Maclaurin expansion.
Note that as accurately as possible is quite a big ask: I hope the marker is going to allow something that is reasonably accurate.
Likes ver_mathstats
It's only a homework practice problem to help us code in MATLAB luckily :)
Likes pbuk
I'm working on this question right now, would it make sense to write a for or while loop for the maclaurin series of e^x to obtain a value for a certain number of terms and then input that number into the rest of the function? Or am I way off?
You have to be careful about rounding errors, so I wouldn't simply replace the exponential with its Maclaurin series. Write it on paper first and see if there is a way to simplify the function mathematically first.
You will eventually end up with an infinite sum, which can be implemented in a truncated form using a for loop. You might want to figure out first how many terms you need to keep to get a valid result for all |x| < 1. Tip: start by summing the smallest terms first to reduce the truncation errors.
You are not way off at all. I would write a while loop which will enable you to make a better choice for termination than after a fixed number of iterations.
One thing though, you are trying to calculate f(x) not ## e^x ## so don't forget to change your series to reflect this
it should end up with fewer terms and converge much faster
Whoops sorry about that. I misunderstood the problem
  • · Replies 16 ·
