Coefficient of friction from a graph
5 replies · 19K views · last reply
nehcrow
Is it possible to find the coefficient of friction just by looking at a graph?
A velocity-time or acceleration-time graph which models a particle going up a ramp and down a ramp.
You would need at least some kind of additional information.
Even if there are no external forces but gravity on the block, and your acceleration-time graph is just a constant you would still be unable to find the coefficient of friction without at least knowing the angle the ramp makes with the horizontal.
No that's not right
You do not know inclination as well. So you have got two equations and two variables. What else do you need?
I could generate two identical velocity-time and acceleration-time graphs, for two different situations with different ramp angles and different coefficients of friction.
We are talking about one graph of moving up, and the other moving down. The two situations are well connected. You cannot change the coefficient of friction or angle in between the motion. If you feel you can generate the graphs then please do and post.:smile:
There should only be a single acceleration graph.. unless there are other forces acting on the block other than gravity. The gravitational acceleration on the block does not care if the block is going up or down, the acceleration is constant. Therefore the acceleration-time graph is just a straight line, and fully describes the block moving up and down the ramp together with the initial velocity and position, no second graph is required.
Well the acceleration experienced by the block regardless of whether it is going up or down the ramp and regardless of whatever its velocity is will be found by:
in general
[tex]F_{friction} = \mu F_{normal}[/tex]
[tex]F_{friction} = \mu mgcos\theta[/tex]
the component of gravity down the ramp will be:
[tex]F_{g_{x}} = mgsin\theta[/tex]
So the total force is:
[tex]F = F_{g_{x}} - F_{friction}[/tex]
[tex]F = mgsin\theta - \mu mgcos\theta[/tex]
So the acceleration is in general:
[tex]a = g(sin\theta - \mu cos\theta)[/tex]
Then from this the velocity is simply the integral, we find:
[tex]v = g(sin\theta - \mu cos\theta)t + v_{0}[/tex]
So for example, with a ramp angle of pi/4 and a coefficient of friction of 0.2, the acceleration is directed down the ramp with a magnitude of 5.544m/s^2
However, it is easy to verify that a ramp angle of pi/3 and a coefficient of friction of 0.601 also has an acceleration down the ramp of 5.544m/s^2
There should actually be an infinite amount of combinations of ramp angle and coefficients of friction that will give the same acceleration.
If the acceleration is the same, then the velocity and position graphs are also the same. (provided that all situations have the same starting point and initial velocity).
