Coefficient of Thermal conductivity
4 replies · 2K views · last reply
imselva
TL;DR
K depends on temperature. K varies with temperature. For all the materials we have a tabular data of K for different temperatures.
While calculating Q for which temperature K value has to be taken?
Which K value is valid?
We know that,
Conduction Heat Transfer Q = KA(t2-t1)/thickness
K is the coefficient of thermal conductivity. If T2 = 1020°C and T1= 22°C also consider we know A and thickness value.
The equation Q = KA(t2-t1)/thickness is only valid in case the coefficient of thermal conductivity can be assumed to be about constant in the given temperature range.
If it is not constant, how to calculate it analytically?
Is there any other relation to calculate Q
Heat conduction problems with temperature dependent material properties are preferentially solved using numerical methods.
$$Q=-kA\frac{dT}{dx}$$so $$Q\Delta x=-A\int_{T_1}^{T_2}{kdT}$$
