Collapse of the electron wave function due to inelastic interactions
  • Context: Graduate
  • Thread starter Thread starter Philip Koeck
    Electron Wave function
The discussion revolves around the effects of energy loss on phase contrast imaging in transmission electron microscopy (TEM), particularly focusing on the implications of using a phase plate that alters the energy of unscattered electrons. Participants explore the relationship between wave function collapse and phase contrast, as well as the potential impact of energy variations on imaging coherence.
  • Some participants assert that the energy loss from a phase plate (around 1 meV) is unlikely to cause a wave function collapse or significantly affect phase contrast, given that the energy spread of the electron source is much larger.
  • Others argue that while the energy variation from the source does not typically allow for path localization, a phase plate that changes the energy of unscattered electrons could enable such localization, potentially impacting phase contrast.
  • There is a discussion about the nature of the wave function and whether it is a physical object, with some suggesting that this topic belongs in a different subforum.
  • One participant notes that the linearity of the Schrödinger equation is incompatible with the concept of collapse, regardless of interpretation.
  • Concerns are raised about the stochastic nature of energy variations and their potential to degrade coherence in imaging.
Participants generally do not reach a consensus on the implications of energy loss on phase contrast. Multiple competing views remain regarding the effects of energy variations and the interpretation of wave function collapse.
Participants highlight limitations related to the assumptions about energy variations, the dependence on detection setups, and the unresolved nature of how these factors interact with phase contrast imaging.
Philip Koeck
I'm wondering about phase contrast imaging with a transmission electron microscope (TEM).
It's generally accepted that phase contrast arises because scattered waves interfere with the unscattered wave when they meet again in the image plane.
It's also well established, I believe, that each electron only interferes with itself, since it's possible to decrease the beam current so much that the electrons are several mm apart on average.
If I now place a device in the back focal plane (where the diffraction pattern is located) that enhances phase contrast (a phase plate) this device could also change the energy of the TEM-electron.
For example the unscattered component of the wave could loose a small amount of energy whereas the scattered components don't, whatever that means since we're talking about a single electron here.
Would such an energy loss immediately make the wave function collapse and destroy phase contrast?
In particular the phase plate I'm thinking of consists of a dilute cloud of electrons located in the back focal plane on the optical axis of the TEM. The energy change of the unscattered electrons (with 200 keV kinetic energy, for example) is in the order of 1 meV.
... The energy change of the unscattered electrons (with 200 keV kinetic energy, for example) is in the order of 1 meV.
No, it won't have a dramatic effect, and will certainly be nowwhere near to what phenomenologically could appear like a wave function collapse.
Why do I believe this? Because the energy spread of your electron source will already be significantly bigger than 1 meV. And this has basically no impact on the imaging either. Of course, one could also try to compute which impact it could have, but if the result of the computation would contradict what is already known from experience, believe me, the mistake will be in the computation, not in the experience.
Is the wave function a physical object? If not, what is collapsing?
That depends on the interpretation we've chosen. Any further discussion of that question belongs in the Interpretations subforum - discussion here will only hijack the thread.
The Schrödinger equation is linear. Linearity is incompatible with collapse at a purely mathematical level, independently on interpretation.
Maybe I'm overthinking this, but isn't there a fundamental difference here.
The energy variation from the source or even due to the specimen doesn't allow me to locate the path of the electron in most cases.
However if I have a phase plate that can change the energy of an unscattered electron, but doesn't change the energy of scattered electrons so much, I can, in principle, know where the electron went if it lost or gained enough energy.
So, if I wanted to and had the necessary technology (spectrometer with meV resolution), I could know whether the electron was scattered or not.
Would that kill phase contrast?
Of course there is a difference, but the fact that the energy spread of the electron source is significantly bigger than 1 meV nevertheless allows you to conclude that the electron optics for the detector won't be affected much. What the energy variation could do is to impact the actual phase shift, but you can include this effect in the design of the phase plate optics.
Careful, you are working with phase contrast here! This means that the actually used detection optics will be such that the detected single electron was both scatter and not scattered at the same time, phenomenologically. If you use a a different detection setup, which can distinguish those energy differences, then this is no longer the case. The detected electron will then either be scatter or not, phenomenologically.
But this change was cause by your detection setup, not by the phase plate slightly changing the energy of unscattered electrons.
James112 said:
Phase contrast in TEM relies on interference between scattered and unscattered waves. A phase plate in the back focal plane shifts the phase of unscattered electrons, enhancing contrast. If your phase plate causes a small energy loss (~1 meV), it’s unlikely to destroy phase contrast, as 1 meV is negligible compared to 200 keV. However, if it induces inelastic scattering or random energy shifts, it could degrade coherence. The impact depends on whether the energy loss is consistent or stochastic. Are you considering this for an experiment or as a theoretical idea?
It's for an actual phase plate I'm working on.
The energy variation is definitely stochastic.
  • · Replies 23 ·
9K
  • · Replies 17 ·
