Collisions- Simple Algebra Problem
The discussion revolves around solving an algebra problem related to elastic collisions between two blocks. The user initially struggles with applying the conservation of momentum and kinetic energy principles to find the final speed of block 1 after the collision. Clarifications are provided on the correct expressions for momentum and kinetic energy, leading to a simplified equation for the final speed. The user confirms their understanding after receiving guidance on rearranging the equations to isolate the final speed variable. Overall, the conversation highlights the importance of correctly applying algebraic principles in physics problems.
verd
Collisions-- Simple Algebra Problem...
Hi,
So... I think I'm having a simple algebra problem-- I was just wondering if someone could point out my error. This is the problem:
Block 1, of mass m_{1}, moves across a frictionless surface with speed u_{i}. It collides elastically with block 2, of mass m_{2}, which is at rest (v_{i}=0). After the collision, block 1 moves with speed u_{f}, while block 2 moves with speed v_{f}. Assume that m_{1} > m_{2}, so that after the collision, the two objects move off in the direction of the first object before the collision.
[Image]
What is the final speed u_{f} of block 1?
So-- I find m_{2}v_{f} using the law of conservation of momentum:
m_{2}v_{f} =m_{1}u_{i}-m_{1}u_{f}
And I find m_{2}v_{f}^2 using the law of conservation of kinetic energy:
m_{2}v_{f}^2 = m_{1}(u_{i} - u_{f})(u_{i} + u_{f}).
Then I find v_{f} using only u_{i}, and u_{f}:
v_{f} =\displaystyle{\frac{-(u_{i}+u_{f})-(u_{i}+u_{f})}{-2}}
Now, I have to substitute what I just found for v_{f} into the conservation of momentum formula, and solve for u_{f}. ...But I guess I'm having difficulty singling out the u_{f}.
This is what I've got:
m_{1}u_{1} = m_{1}u_{f} + m_{2}(\displaystyle{\frac{-(u_{i}+u_{f})-(u_{i}+u_{f})}{-2}})
...And here, I think I messed my algebra up, but when I simplify that, I get:
m_{1}u_{1} = m_{2}(u_{f} + u_{i}) + m_{1}u_{f}
Is that right? ...If not/if so, how do I get the u_{f} on just one side?
OK.
OK.
I have no idea what you are doing here. This expression simplifies to: v_{f} = u_{i}+u_{f}, which is incorrect.
You can rewrite the momentum equation to get
v_{f} = \frac{m_1}{m_2} (u_{i} - u_{f})
Perhaps this is what you meant? Now just plug that into the KE equation to eliminate v_f and simplify.
Amazingly, it is right. (It's equivalent to what you get when you do the "plugging in" that I suggest above.) So I suspect you made a typo earlier on. To simplify this expression, just multiply it out and move all terms containing u_f to one side and all other terms to the other side.
woo, okay. thanks. I got it. ...Really, much appreciated.
Thanks again... (Eh, I'm having a really hard time in this class- if you couldn't tell. AND I made the mistake of taking it as a 7-week course. ...I obviously didn't know what I was in for. Really, thanks again.)
