Column Loading Analysis: Strain and Stress Graph for Tubular Support
  • Thread starter Thread starter oxon88
    Complex Systems
39 replies · 9K views · last reply
post #13 has the correct figures.
Thanks, and this part...
show how four strain gauges can be used in
conjunction with a Wheatstone bridge to give maximum sensitivity
of the load measurement system.With the aid of sketches show how four strain gauges can be used in
of the load measurement system. Show clearly the orientation of the
strain gauges on the tubular column and the positioning of these
gauges on the Wheatstone bridge
take a look here: http://www.omega.com/faq/pressure/pdf/positioning.pdf
for this question, i explained how the circuit works and what the benefit is using the wheatstone bridge circuit. look at figure D in particular for the positioning of the strain gauges.
quick couple of questions and many thanks so far.
Have you had this all marked??
Also the table in post#13 are the same values I had calculated for the graph of the expected strain against the applied load. How do these work then for the graph of strain against applied load when the strain gauge is in
the new position?? Just a bit confused?
yes it has been marked as correct. I achieved distinction grade.
for the first graph, it wil be Transverse Strain Vs Load
for the second, it will be Longitudinal Strain Vs Load
Magic Oxon88 and well done some of these questions are tough to say the least. I will keep working away and try and get it all done. Many thanks for your help. Hopefully in the future I will be able to repay the favour...
Oxon could you upload the Longitudinal Strain Vs Load graph please
Your graph Oxon what have you used for the x axis?
