Coming out with clean values for arccos, arcsine and arctan
  • Thread starter Thread starter caesius
    clean
This discussion focuses on the concept of obtaining "clean" values for inverse trigonometric functions such as arccos, arcsine, and arctan. It highlights that angles with tidy sine and cosine values are typically multiples of 30º and 45º, derived from specific right triangles like the 45-45-90 and 30-60-90 triangles. For example, arccos(3/5) does not yield a clean expression due to its relation to the 3-4-5 triangle, resulting in a decimal approximation rather than a simple fraction of π. The conversation emphasizes the importance of understanding trigonometric identities and the unit circle in deriving these values.
  • Understanding of the unit circle and its properties
  • Knowledge of basic trigonometric functions and identities
  • Familiarity with right triangles, specifically 30-60-90 and 45-45-90 triangles
  • Basic understanding of radians and their relationship to degrees
  • Study the derivation of sine and cosine values from the unit circle
  • Learn about trigonometric identities and their applications
  • Explore the properties of the 3-4-5 triangle and its significance in trigonometry
  • Investigate the relationship between rational and irrational numbers in trigonometric functions
Students in mathematics, particularly those studying trigonometry, educators teaching these concepts, and anyone interested in understanding the relationships between angles and their trigonometric values.
caesius
Coming out with "clean" values for arccos, arcsine and arctan
Not so much a homework problem just something that bugs me and it's taken until first year Uni math before I asked it.
In the text or in lectures when taking the arccos of say, 1/root2, the lecturer won't write 0.7853..., but rather a very nice looking pi/4.
How does s/he know this? It seems like they know a "nice" way of writing every arc function value.
At the moment I need arccos(3/5), what about this one, is there a nice way of writing this? Instead of 0.927...
Cheers.
Really it's all about playing around with the unit circle (http://en.wikipedia.org/wiki/Unit_circle). The circle contains some simple angles (30,45,60, and 90 degrees, along with 90 degree shifts of all of these angles all of the way around the circle) represented in radians and the value of sine and cosine at those angles. You can derive the values of sine and cosine by considering the 45-45-90 and 30-60-90 right triangle, and looking at the trigonometric properties that follow.
For other angles, the answer may not always be "clean", though you can often write the solution as a sum of "clean" values by using some basic trigonometric identities (search around, they're all over the web).
theUndergrad
http://www.theUndergraduateJournal.com
To elaborate a bit on theUndergrad's reply, the angles that have the tidiest sines, cosines, etc. are those which are multiples of 30º and 45º. The right triangle with two 45º angles is a right isoceles triangle, which can be assigned sides of 1, 1, and sqrt(2), so the trig functions for 45º are built out of the possible ratios of those numbers. The 30º-60º-90º triangle is a bisected equilateral triangle; if we take its sides to be 2 , then the sides of our triangle will be 1, sqrt(3), and 2 , so all the trig functions for 30º and 60º are built out of all the possible ratios of this set of numbers.
The inverse trig functions then give the simple divisions of pi radians (pi/6, pi/4, and their multiples) for the ratios involving 1, sqrt(2), sqrt(3), and 2. Other even subdivisions of pi will be related to somewhat more complicated ratios through the application of various trigonometric identities.
So it is unfortunately the case (the ancients -- particularly the Pythagoreans -- would have been horrified!) that the simplest angles are connected with ratios involving irrational numbers and, by contrast, that simple ratios of integers are connected through the trig functions to not-at-all-simple angles. Your particular inverse trig function relates to the 3-4-5 triangle, which does not have angles which are simple fractions of 180º or pi radians, so values like arccos(3/5) don't have "clean" expressions, and instead we have to live with decimal approximations.
IMHO, arccos(3/5) is already a "clean" expression. :smile:
  • · Replies 29 ·
  • · Replies 17 ·
