hisotaso
- 26
- 0
ii = ie + α[/color]reie/R4rude man said:ii = ie + reie/R4.
finally giving
Ai = ic/ii = α/(1 + α[/color]re/R4) ~ α.
NascentOxygen said:ii = ie + α[/color]reie/R4
Negligible difference, but the algebra looks neater.
hisotaso said:I have had a lot of problems with this text so far, approximations, incorrect solutions...However, I was using this other text on google books as a reference:
http://books.google.com/books?id=bXsWq0sq-WEC&pg=PR3&lpg=PR3&dq=biased+common+base+circuit+analysis&source=bl&ots=An5Z7MIMDV&sig=-qRuW6p_znsC9qMFrja7bXWAgkU&hl=en&sa=X&ei=kfyjUYn0BejXiAKfnIAY&ved=0CFEQ6AEwBA#v=onepage&q=biased%20common%20base%20circuit%20analysis&f=true
If you scroll down to page 1-22 you see this author is using the same equation, I don't understand it :/. Thank you for your input.
rude man said:The reason you don't understand it is that it's wrong. Read my post #5 again.
hisotaso said:As far as confusing symbols, yes I am aware that the symbols are not the same, so let me be more specific. In the attachment that shows my actual problem statement, my small signal drawing, and the given solutions, how does one arrive at the divider term R4/(R4 + Ri)? Ri in that problem is the resistance from the source, not input resistance, which is labeled Rin.
hisotaso said:Thank you for your input. The use/lack of use of ro was a source of confusion for me, and I asked about that somewhere else. I was told that not only would it make a very messy equation, but in fact it had little effect on the results. (I wish the author had explicitly stated this in the text, but that is another issue)
Once again thank you for taking the time to reply.
hisotaso said:I see now that my error was attempting to explicitly solve for ie and ii and calculate the ratio, rather than summing currents at the emitter. I often stare so hard at a problem that I get lost in it and get stuck looking at it one way, not seeing the trees for the forest as it were. You have been an immense help, and I thank you for having the patience and taking the time to reply. Also thank you to everyone else who has contributed.
Regards,
JC
