Commutator Proof: Show (x,p^n)= ixp^(n-1)
  • Thread starter Thread starter The Head
    Commutator Proof
The discussion revolves around proving the commutation relation (x, p^n) = ixp^(n-1) using the known commutation relation (x, p) = i. Participants successfully demonstrate the base cases for (x^2, p) and (x, p^2), but struggle with the induction step for (x, p^n). They explore various approaches, including expanding terms and applying induction, but encounter difficulties in isolating the necessary factors. Some participants suggest that there may be an error in the problem statement regarding the presence of "x" in the final expression. Overall, the conversation highlights the challenges of applying induction in operator algebra.
The Head
Using (x,p) = i (where x and p are operators and the parentheses around these operators signal a commutator), show that:
a)(x^2,p)=2ix AND (x,p^2)=2ip
b) (x,p^n)= ixp^(n-1), using your previous result
c)evaluate (e^ix,p)
For operators, in general:
(ab,c)=a(b,c)+(a,c)b
(a,bc)=(a,b)c + b(a,c)
I have no trouble showing (a):
(x^2,p)=x(x,p)+(x,p)x=x(i) + i(x)=2ix
Same general strategy for (x,p^2)
In (b), I get lost when trying to apply the result I have already found. My attempt:
(x,p^n)=(x,p*p^(n-1)=(x,p)p^(n-1)+p(x,p^(n-1))=ip^(n-1) + p(x,p^(n-1))
I don't know where to go from here. I have tried pulling out more factors of p from the second term, but that gets me no where (at least from what I can see). I have also just played around a lot with the commutator, even starting from the end:
ixp^(n-1)=(x,p)p^(n-1)= xp^n - pxp^(n-1), but again, after this, whichever path I take doesn't seem to be fruitful.
Thanks!
Do you know how to do proofs by induction? It looks to me like the problem wants you to do it that way.
An induction proof goes as follows: First you proof some base case, such as N = 1 (like part A). Then you assume it's true for some n -1, and show that implies it's also true for N. These two steps show it's true for all N.
I thought about an induction proof-- I have some experience with these, but evidently not that much. After I get to where I left off:
I have to somehow turn this into ixp(n-1). I can't figure out how to get an "x" in the final expression that is separate from the commutator. I have tried expanding the second term further:
p(x,p^(n-1))=p(x,p*p^n-2)=p(x,p)p^(n-2) + p^2(x,p^(n-2))= p*i*p^(n-2) +p^2(x,p^(n-2))=ip^(n-1) + p^2(x,p^n-2)
Together with the first term I have:
ip^(n-1)+ip^(n-1) +(x,p^n-2)=2ip^(n-1) + (x,p^n-2) I feel like this only leads to an expression that equals something like nip^(n-1), but I can't find a way to make it "xip^(n-1)" Is it a mistake? Or am I just applying the strategy incorrectly?
It looks like there is an error in the statement you are supposed to prove. [x,p^n]=inp^(n-1). There's no x in there.
For induction, you are supposed to assume that the n-1 case is true. this would imply:
(x,p^n-1) = ixp^n-2.
On the other hand, this approach doesn't quite seem to work, so I think that Dick is right, and there isn't supposed to be an x there.
Of course not, the given formula ought to at least work for the n=2 case.
try this,xpnψ-pnxψ=-(pnx)ψ
